![]() | Home > Maintenance & Modifications > Puma screen washer issues |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Welcome, William
Have a shifty at this thread: http://www.defender2.net/forum/topic18055.html Hopefully it'll help you Some folks have also one an upgrade... http://www.defender2.net/forum/topic17143.html Welcome to the Scottish branch of Defender2.net |
| taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 626
I had a lot of problems with mine a while back, I'm not sure if the puma is the same as the TD5 but under the bonnet tucked away in the passenger side corner, just before the washer pipe goes through the bulkhead is a little plastic non return valve, this was sticking, I removed it and put a small piece of pipe in its place and never had that problem since. I'm not saying that is your problem but well worth a look. Optimists say the glass is half full..
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
| william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259
Thank you, i had a wee search but didn't come across that thread. I was in about it last night and didn't see a non return valve. Ill have a look at pulling it off. William
| All times are GMT |
