![]() | Home > Maintenance & Modifications > Alarms immobilisers etc |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Speak to Tim at Mobile Centre regarding alarms
We have a group buy on the Skytag tracker available as well |
| Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468
Having looked at the 10as on my new puma , I am beginning to think there is a lot of urban myth how bad the alarm is.
The old unit could be snipped behind the headlight and horn shorted out . The new one cannot as it has a battery backed siren. Any alarm can be disconnected and with a bit of time cut out. If nobody responds to the sound , waste of time. I have added to to the 10as , by adding a tilt sensor and impact sensor. If the wheels come off the ground it goes off. Wrench on the spare wheel it goes off. Window break etc. Multi layered approach as in pedal lock , disc lock , tracker will protect your car and deter your casual thief. Bonnet security is rather easy . Abus do a nice flexo steel that prevents that being stolen . If they have 30 mins and an angle grinder it will go anyway. Soon as my bonnet pops the alarm goes off . Security screws on the headlight stop them from getting behind it. Bolt heads can be metal stopped , yes it costs you a bolt or 2 but means they will not have your doors easy. Most professionals will case the car 1st and think , that's not easy money , NEXT . |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
In my younger days
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
The problem is the 10as and immobiliser are built into the key / ignition.
You would have to completely remove it or carry two sets of remotes. And then if it fails to start which one. The clifford avant guard which is now obsolete was probably the best . But even that was easy enough to disable with 15 mins or so. The 1st 3 mins is critical , if it texts you , wakes you . If your 10 mis away its gone. Hence alarm , disclock, tracker , pedal lock , data tag give you a chance. Remember defenders are nicked for parts not joyriding I think . My take is never leave it anywhere vulnerable. Sealing the doors stops your pikeys 3 min stop over. Disk lock / pedal lock stops them driving it somewhere quiet. If they get to mine they will probably fire it as they cannot strip it easy , but this would just make me Life is too short to get too stressed about it . Protect it insure it enjoy it |
| Baggie Austin Member Since: 16 Mar 2013 Location: Birmingham Posts: 102
Cakey have you a link for the abus flexo steel thing for the bonnet, how does it work? |
I have sent you a pm . Think pikeys can read
The only issue that still cannot get my head round , do the thieves have cloned keys ? Or is this another myth .
Even if they have a cloned remote , key is not the same and disclock and pedal lock stop them from moving it easy. Or do they look for cars with no additional security just the factory fit. Would take them a while to strip mine , might ask them to adjust the doors while they are at it. Especially if I leave the 2 Dobies in the back |
Cheers mate, just able to make it out |
| All times are GMT |
