![]() | Home > Technical > Window not working |
My money is on the cables that run in the rubber trunking from the door frame to the door being damaged.
They have been known to cause problems. You should be able to investigate and repair easily. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
bcarlin Member Since: 24 Sep 2011 Location: lanarkshire Posts: 290 ![]() ![]() |
Thanks for the tip
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
As above. Cable from post to door. When you pull the rubber sleeve back it will be one of the two fat wires. Give them a good pull.
Andy |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I had a bust motor on the driver's door. Just needed replacing. It had just burnt out.
I don't think it cost very much to replace. I didn't do it myself. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Wife just told me that the driver's window on our 2008 Puma is not working. Must check those cables.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Managed a temporary reair as the wife was heading out. Could not get the rubber sleeve pared back far enough so I had to slit the rubber sleeve underneath to gain access. Seems it was a break in a previous repair. The break is at the very bottom where the rubber sleeve enters behind the door trim. Does'nt seem to pull forward from the door. Is the only way of accessing this to prise away the bottom of the door trim? I would like to make a better repair and push the join in behind the door trim to stop any strain on the repair. 1982 88" 2.25 diesel
Picked up the 110 tonight
