Home > Puma (Tdci) > Defender puma wiring problem not comunicating to ecu
lrov110
Australia 2009 Defender 110 Puma 2.4 SW Orkney Grey
Hi guys,
Have a slight problem, driving home the engine went into limp home mode. When i started the car again it would run for a couple of km then do exactly the same thing. Abs and traction control lights would stay on, now seems to be getting worse on idle it would just die.
Checked all obvious connections under seat dash and to the ecu sprayed with contact cleaner etc battery leads and earths seem to be fine. Now at a loss on what to do next thinking maybe it could be the computer? or a split wire somewhere in the line???
Fault codes
p1935:Brake switch
p068a:Engine control power relay
p0606:Engine processor
p0404:Exhaust gas
u0155:lost comminication with instrument cluster
p1103: Mass air flow
Any addvice would be much appreciated
Thanks
Post #224505 4th Apr 2013 9:33am
