![]() | Home > Puma (Tdci) > strange loss of power ? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
anyone had this before and did it lead to something worse?
started the engine this moring and left it running for perhaps 1 minutes while scrapping a little ice off and then pull off the drive, engine revs pick up in 1st then into 2nd and the revs died as if some kind of limp mode?? I put the clutch down and revs picked up fine and then no further problems - most peculiar ?? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
bit of diesel gelling momentarily clogging the fuel pickup perhaps? Once the warm return fuel got into the tank, no more gelling?
I would chuck in a bottle of diesel cleaner just to make sure. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
thanks Naks,
could be as you've suggested but although cold today its been colder recently and I'm on the same tank of fuel. re diesel cleaner I'm happy that I don't need anymore of that but what I will do is drain the fuel filter off again (not done that for a wee while)......... ![]() |
strange?
good to hear I'm not alone. I have to say it was one of those things were clearly it wasn't right but it didn't seems like something was waiting to fall off ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
I find it's only really in 1st and 2nd gear. Foot down and momentarily nothing and then bang all the power comes hard. But only when cold and accelerating hard say out of a junction. Does it once and that's it. Also rare to happen but does occasionally. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Don't worry = Caterham ![]() ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
Sounds similar to mine - a momentary hesitation when the throttle is suddenly opened. Most noticeable when changing up, ie throttle open, ease off to shift, then back on throttle and a momentary flat spot as the power comes back.
It's not EGR or map related, but replacing the fuel filter has made a significant improvement. Old filter had a surprising amount of waxy greaselike gunk in it. |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Hmm I wonder if that's why mine went into limp mode last Saturday ?
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
![]() Steve. worry = caterham ![]() not sure if we're talking the same thing here. I wouldn't describe as momentarily, it was like a couple of seconds not just a blip. I still don't see it being any thing serious but more interested in trying to understand what caused it....fuel supply seems like the answer.....must pull my finger out and drain filter for strarters. |
