![]() | Home > Puma (Tdci) > Gearbox oil change done-almost buttery change now ! |
| chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559
im tempted to do mine. its covered 4000 miles now and 2nd and 5th can be quite stiff on cold mornings. i have heard horror stories of the factory underfilling gear boxes and diffs when the leave for showroom/customer.
| macduff Member Since: 04 Nov 2012 Location: NE Posts: 119
Never been a fan of fill and forget strategy most manufacturers have on transmissions these days so even at 4k miles I'd think it was a good thing to do. I just crawled under mine and there was plenty of space to wiggle the Syringe pumps filler tube into the gearbox fill hole, though if your a little uncertain do a dry run with the filler hole before draining the oil out.
I measured just over 2 litres drained out of mine so probably about the 2.2l quoted for a refill once spillage was taken into account. 2023 110 P400e |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296
Well done Macduff ! Its a very satisfying job to have completed knowing the contortionist skills involved isn't it ?
I do mine annually now. When you look at how hard those couple of litres of oil have to work in a Defender Landrover's recommended intervals are nonsense. The 'box will have disintegrated long before 200k ! |
