![]() | Home > Maintenance & Modifications > Front bumper mounted tow ball? |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Think it is Devon 4x4 do a slip over bumper tow ball mount.
Yes it is Bearmach BA3107 on this page Whilst a 2" receiver is normally mounted central on a steering guard it is possible to get them offset by a maximum of about 8" or 200mm to one side Brendan |
| WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748
Thanks Brendan, Ive just searched the Bearmach part and that looks ideal
| ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575
Very old post I know
Chris 2010 Defender 110 Station Wagon, Santorini Black. |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Unless you're only using a small winch (which will be fine) bear in mind that winch bumpers are a lot heavier duty than the standard ones. You're liable to banana a normal bumper if you load up a 9,000lbs winch on one.
Hi Cupboard,
I agree with you, I was thinking of using it off centre, over the chassis leg so that the mounting didn't do what you suggest and banana the bumper. But will it fit either side of the chassis leg mounting? looks like it's designed to do that. Can any users advise? Chris 2010 Defender 110 Station Wagon, Santorini Black. |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
Think it usually goes each side of the chassis rail.
But I wondered if it would still fit if your Defender has A/C as the grill sticks out further and might stop it from fitting over the top of the bumper? Here is the one sold by Simmonites: http://www.simmonites.com/shop/vehicle-acc...tow-hitch/ Last edited by DAZ110 on 18th Nov 2016 5:33pm. Edited 2 times in total |
Daz110,
Good point, I'll have a look see. Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Also very close to the number plate by the looks of it ?
I may have to remove the grill to put it on, but if it's black I can leave it on there semi-permanently. I don't think it will affect the number plate.
Chris, let us know how you get on.
