![]() | Home > Puma (Tdci) > Mud Roof Console |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
ok.......
I have now fitted the centre and right hand side of the console (it comes in 3 sections). Easy installations I must admit. One or two hickups - nothing major. They want you to drill a 4mm hole into the door frame top, but also fit a 4mm self tapping screw. Drill using a 3,5mm rather. And the first step suggest removing a fir tree fastener at the same location, but I kept it in .Didn't make sense to remove it... Using it will be the ultimate test though...... I think it's quite sturdy and it looks the part for sure!!! This should come standard with any landy!!!!!! |
BjornAgain Member Since: 29 Oct 2012 Location: Johannesburg, South Africa Posts: 22 ![]() ![]() ![]() |
Show us some pics!!!!!! |
Were they saying remove the fir tree and make use of that hole instead of drilling another? Steve.
they didnt mention that that was the case - just to remove it. But the hles doesnt line up anyways so you have to drill new ones in any case. Just leave those fir trees (save the planet) ![]() Will post some pics once I get a chance! |
