![]() | Home > Technical > 2.2TDCi Smoothness (or not!) |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
I did and downloaded a lot of stuff. Most is in PDF format |
Tony Member Since: 13 Mar 2012 Location: West Yorkshire Posts: 72 ![]() ![]() ![]() |
Thanks for that John, most helpful! I will definitely tell the garage about the jerkiness and gear changes (which can be fine some days and not so good on others) as the only outstanding Topix issue on mine is Q205 Charge Air Cooler Hose & Coolant Hose Spring. Cheers! ![]() Tony |
J8GHX Member Since: 22 May 2012 Location: Hampshire Posts: 154 ![]() ![]() ![]() |
Hi Tony,
The field service actions are different to recalls and software updates. Recalls are for a safety related issue and the manufacturer has to contact owners by law. Field Service Actions are where the manufacturer chooses to make a modification to the vehicle to stop a problem happening which they're aware of and has affected many vehicles. They can do these whether the vehicle is under warranty or not. (It's worth checking every age of vehicle for outstanding service actions, my next door but one neighbour has just had nearly £1500 of work done to his 1994 P38 Range Rover, FoC as an outstanding action! He only found out after putting it in Topix and the dealer honoured it without question!! Software Updates are not installed as a matter of course, like would happen on an iPhone for example. They can be applied to help rectify a fault or symptom, but if the car doesn't need it or the owner hasn't complained, it won't be installed. It's a bit like an antibiotic. You get a specific type for a specific problem! John. Currently....... all gone...... pending delivery of a mid life crisis....... Previously..... Quite a few! I really am a sucker for them! |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
[quote="J8GHX"]PS it's applicable to some 13MY also.
You'll find details of the software patch on Topix, and it shows the chassis number range which it's useful for. John[/quote Which ref number is it, the only one I can find is to do with flat spots when changing gear, nothing specific to slow speed jerkiness or and DPF faults? |
Photoguy1510 Member Since: 02 Apr 2013 Location: Wellington Posts: 25 ![]() ![]() ![]() |
New software for my13 110 release note 17 April 2013- do we get a smoother ride without kangaroo jack under the bonet?
Is there any way to see what is addressed by this update? 2013 Orkney Grey 110 SE on order should be here on 20/04 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3465 ![]() ![]() |
A very old thread l know, but it "died" without any real answer!
This fault is still apparent on many 2.2 Defenders. l would guess most never had the software update which was mentioned on this thread. lf l can find a dealer with Topix will the software still be available from 2013? l know my local independent LR dealer has Topix. How would they find out if the software was still on the system? |
