Home > Maintenance & Modifications > CV Joint wear (Title change from Front Diff on the way out?)
Page 2 of 3 <123>
Laurie
Jack up the front axle and try turnig the wheels.
You should be able to localise the noise.
Post #223985 1st Apr 2013 8:01pm
jst
does it do it without the engine running? jack and test.
the noise doesnt sound fast enough to be rotational shaft/cv. sounds more like a pas pump straining under load to me.
is the frequency road speed or engine speed related? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #223988 1st Apr 2013 8:06pm
x-isle
There is a relation to the road speed. The noise increases in frequency when the road speed increases not the engine speed.
I will get the front up on axle stands tomorrow for a better look.
PAS is a possibility though as it would make sense why there there isn't any feedback. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #223996 1st Apr 2013 8:36pm
LR90XS2011
Dont know how, but is it worth pulling the fuse from the ABS/TRACTION control and isolating that from your fault finding DEFENDER 90 TDCI XS,
Post #223998 1st Apr 2013 8:45pm
x-isle
Aleady done that, noise stays but of course the TC doesn't kick in. Craig Rogers
2007 Puma 110 XS
Post #224000 1st Apr 2013 8:47pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Might be worn splines on a front drive member allowing the cv joint splines to slip within it,this would let the diff send the drive to that wheel as there is minimal resistance ,if this shaft increases speed significantly then the traction control would cut in as it thinks a wheel is spinning.Just a theory but its easy to just pop the drive members off and check them.Good luck. 2005 Td5 90 XS
Steve
Post #224003 1st Apr 2013 8:55pm
x-isle
Now that is a possibility. Slight movement of the cv could indeed amplify the effect as it sits on the end of the shaft. Craig Rogers
2007 Puma 110 XS
Post #224007 1st Apr 2013 9:04pm
Lou Sparts
It,s not exactly unknown for Land Rover to "forget" to grease the drive members during assembly ! 2005 Td5 90 XS
Steve
Post #224008 1st Apr 2013 9:08pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
Hmm....doesn't sound like any CV going I've ever had. They are normally quite distinct. The first thing you normally hear (and usually feel through the steering) is a heavy clicking sound (sensation) when on full lock and under load. This comes from the internals of the CV wearing and usually happens way before it breaks.
P.S. I'd NEVER buy a Britpart CV...EVER!
Andy.
Post #224011 1st Apr 2013 9:22pm
Glynparry25
Best thing to do is just start with the basics- don't order anything yet.
Jack and support the front axle. Take the wheels off and have a good look around at the following:
Bearings
Wheel speed sensors
Brakes
Steering.
Everywhere else.
I remember a while ago where a member had a bad wheel bearing where it was causing all sorts of ABS/ TC faults. Turned out that the bearing was enough to put the wheel speed sensor out and was randomly applying ABS/TC.
Make sure the wheel speed sensors are correctly in place- they are known to come a little loose.
It doesn't sound like it is grinding/ notchy so 'shouldn't' be CV- you normally know when a CV is going through the feedback and sound.
With the steering, check the ball joints and the steering damper too.
Everywhere else..... This is where having a dusty/ dirty chassis helps- just have a good nosey around for any clean spots- most likely where something has been rubbing.
Glyn Dog Sheep
Post #224012 1st Apr 2013 9:27pm
x-isle
Cheers for all the help so far.
I'll be doing some spannering tomorrow evening and I'll let you all know what I find.
Glyn, interesting read about the bearing knocking the speed sensor out........ Very interesting. My first thought when it started to happen was wheel bearing, but I discounted that after the first TC issue, now it's back on the list. Craig Rogers
2007 Puma 110 XS
Post #224025 1st Apr 2013 10:50pm
x-isle
Ok, so here's a new theory......
I had to drive it into work this morning which gave me 10 miles of country lanes to have a good listen and do a few tests;
I'm edging towards the noise coming from engine drive and not from the transmission. Therefore, as mentioned before, I now suspect the PAS pump making the noise which is another reason for not getting any feedback through the steering wheel, pedals, or arse.
But......why does the Traction Control kick in?
Question? Am I right in thinking that the ABS/TC module takes a steering position input? I'm guessing it must do to accurately work out expected wheel speeds?
If so, here's my theory...... Mr. Green
When turning, the PAS is activating and turning the wheels. All good so far, however, it's possible that the PAS is not returning back to straight properly, however, mechanically the wheels are straight. This then confuses the ABS/TC and is not expecting both front wheels to be spinning equally.........Voila, Traction Control is activated?
In a sadistic way, I'm actually enjoying this! Twisted Evil Craig Rogers
2007 Puma 110 XS
Post #224042 2nd Apr 2013 8:36am
Glynparry25
Unfortunately ABS/TC has no link to steering.
The difference in wheel speed has to be more than you will ever get steering (for TC) or locked up (for ABS).
Have you got a Nanocom that you can plug in to monitor the speed readings of each corner whilst driving? (or can you borrow one?). This will help you recognise which corner is triggering the ABS/TC.
With Defenders you barely feel (feedback) anything through the steering- they are great like that when on rough roads....... not so good for fine fault finding.
They might not even be related- just happened at the same time.
Glyn Dog Sheep
Post #224043 2nd Apr 2013 8:54am
x-isle
That blows that theory! Mad
I've got Torque (android App)which can output that info, so I'll give that a go too.
EDIT: Actually, I don't think Torque can do that.... Craig Rogers
2007 Puma 110 XS
Post #224044 2nd Apr 2013 8:56am
x-isle
Hmmmm, interesting.......
http://www.lro.com/forum3/viewtopic.php?f=18&t=47984
I've PM'd him the recording! Craig Rogers
2007 Puma 110 XS
Post #224047 2nd Apr 2013 9:17am
Page 2 of 3 <123>
