Home > Technical > Help needed - front propshaft broken off!
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Hi all
Fortunately not mine, but buddy phoned me just now with apparently large problem. Stuck in field 30 miles away.
Td5 propshaft broken off at transfer box end! Can't engage high ratio although drives in low ratio ( propshaft rotates from diff end by the sounds of it)
Any ideas what might have gone wrong? I'm suspecting some sort of seizure in transfer box?
He's only had it for three days so a bit gutted obviously.
Need to sort out some sort of recovery now.
Ta
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #223851 1st Apr 2013 12:47pm
Which prop shaft has gone? Rear I assume? whichever it is front or rear un-bolt the broken shaft at both ends right back to the flange. At least then there can be no further damage from it moving around. Also it would then at least give front or rear wheel drive dependant on which has gone. As long as it's taken steady it should be okay as is. Hopefully both aren't damaged though! ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #223855 1st Apr 2013 12:53pm
d j hutton
Thanks for the reply.
It's the front one, I forgot to say.
Much as I suspected re getting it home, problem is know to work out what's 'gone'
Dj 1989 200tdi 90 csw
Buy British 🇬🇧
Post #223856 1st Apr 2013 1:04pm
bob neville
DJ
Not the high/low linkage seized or broken is it ? Can't see why that would break the prop but may explain why he can't get into high ratio.
2013 Defender 90 CSW - sold
Post #223859 1st Apr 2013 1:10pm
If Hi range isn't available then it's only really a tow home job then. Confused ____\We|Will|Win/___
Post #223861 1st Apr 2013 1:14pm
Laurie
Remove the front proshaft.
Jack up each front wheel to see if it turns.
If so, should be OK to attempt to drive or tow out.
Post #223862 1st Apr 2013 1:15pm
bob neville
I would agree with that Neutral
DJ - in a field 30 miles in which direction, maybe one of us is close to him and could lend a hand/help ?
Post #223865 1st Apr 2013 1:18pm
d j hutton
bob neville wrote:
DJ
Bob
That's what I suspected, but I'm thinking something more catastrophic to break the propshaft off. He's over New Milton way and it sounds like AA might be sorting out a recovery for the time being.
On the bright side if its a transfer box failure then it might be an opportune time to upgrade to a disco ratio one Thumbs Up
We,ll see what the AA man has to say.
Buy British 🇬🇧
Post #223871 1st Apr 2013 1:42pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Obviously if he does try to drive it after removing the prop he needs to have diff lock engaged to get any drive to any of the wheels.
Post #223872 1st Apr 2013 2:11pm
d j hutton
Thanks for the replies chaps, turns out it probably isn't as bad as originally thought.
The UJ on the front of the transfer box appears to have collapsed which allowed the prop to come away. yoke on the transfer box is broken and spider had it. So tying to source parts for it today, hopefully its possible to buy the front yoke an spider as separate parts instead of a complete prop!
The lack of drive in high range turned out to be user error Whistle as a new owner he was having trouble selecting high range, thinking it was a 'normal' type of gear box! So hopefully thats all going to be ok - we'll see.
Buy British 🇬🇧
Post #224045 2nd Apr 2013 9:01am
