Home > Maintenance & Modifications > Door hinges
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Door hinges
Any one got any experience of after market hinges as my standard ones have a lot of play in them specially drivers side ?
Any site sponsors sell them good ones ?
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #223545 30th Mar 2013 8:41pm
WarPig
I got mine from here..
http://rjlandrovers.co.uk/defender/83-defender-door-hinges.html
Mines a 300tdi and the hinges they supplied at the time were for the Td5. I needed to change my hinge gaskets to the Td5 gasket.
They came in white and I had them resprayed. Still in perfect working order 3 yrs later. Just watch you dont loose the captive nuts inside the A pillar!
Post #223588 31st Mar 2013 12:31am
mikeh501
I've got some hinges from flatdog which are zinc plated unlike the others I saw on eBay etc
Post #223595 31st Mar 2013 6:20am
leeds
Drivers door on 09 110 was dropping on opening door due to play in bottom hinge. Door adjusted up ok.
Many different aftermarket hinge blocks out there.
I think LR spray doors after fitting hinges so when you remove hinge there is a paint line/ridge. If the replacement hinges are the same size or a fraction smaller you may well see the paint line.
Some of the aftermarket ones have a slightly larger footprint and that solves the problem.
If you like the stainless door hinges from Safari Euip I could work out a price and availability for you.
Brendan
Post #223623 31st Mar 2013 8:48am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Both my lower hinges died so i bought some m8 stainless cap head bolts removed the pins and drilled and tapped the hinges to suit. Works a treat and way cheaper than new hinges. Rhubarb and custard let fly with their secret weapon.
Post #223698 31st Mar 2013 5:22pm
