![]() | Home > For Sale & Wanted > FS Exmoor Trim Seat Risers |
| buellbeast Member Since: 28 Nov 2009 Location: RLD Land Posts: 94
For Sale
Exmoor Trim seat riser new in box as sold HERE for £75 + vat + carriage The seat riser gives you extra legroom and more comfort. These adjustable risers are installed beneath your existing seat runners and allow you to tilt and adjust the seat to your desired position by adjusting the height and rake of your seat. The seat riser will create more space between the steering wheel and seat back which makes this product ideal for the taller driver. Its substantial powder coated steel frame allows you to mount the seat runners forwards or backwards in three different locating points. The seat riser is easy to adjust by releasing the bolt clamps (two on each side) and setting your seat into one of its 21 new position and then bolt lock into place. This can also be used with centre seats or cubby boxes fitted. £60 delivered |
No sensible offer refused
| All times are GMT |
