Home > In Car Electronics > Defender 130 rear view camera
Page 2 of 3 <123>
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
FCX, you got me wondering tonight. Where does the cable leave the the cabin?
About the headunit, have been adviced for a Clarion with satnav today. Have to investigate in the navigation part. Sounds attractive if I don't have to stick the Garmin to the windshield with all the wires.
Lucky me, two weeks time figure it out when I'm abroad. Mr. Green
Post #223264 29th Mar 2013 8:00pm
If you wanted the Garmin with no wires all over the place I could help you out with that... _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #223266 29th Mar 2013 8:05pm
tookaphotoof
Steve, if TMC keeps working I'm all ears! Mr. Green
Post #223277 29th Mar 2013 8:38pm
I can't see why not.. After all surely the purpose of the cigarette lighter is just to provide power I'd have thought. Maybe I'm wrong on that.. Quite happy with mine all the same no plug in the way of the gears OR the cable all over the place. Oh and without having to set the damned lot up every time you want it. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #223278 29th Mar 2013 8:44pm
tookaphotoof
Ah ok, I was actually thinking about just a short cable coming out of the top op my dash and everything else hidden away. Are we thinking the same now?
Post #223285 29th Mar 2013 9:12pm
Yes, That's exactly how I have set mine up. Thumbs Up Invisible wiring except for just a small amount and plug when plugged into the Sat nav it's self. Without the Sat nav in use it just tucks down the rear out of the way. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #223288 29th Mar 2013 9:15pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
steve i am going to butt in again with my double din..... Very Happy
tookaphotoof this is what i have in my 130, its a pioneer f920bt with 2 videos/sources in and one is especially designed for a reversing camera that comes up when reverse is selected.
Post #223304 29th Mar 2013 9:51pm
tookaphotoof
Well, that is actually the ideal situation, apart from the fact you guys did post a link of some Swiss company selling front panels for a million Francs? Mr. Green
Two camera's would be one for not reversing into city go karts and one to keep an eye on the dogs. Cool
And a bit off topic, but where f*** can I find the bloody OBD port?
Post #223309 29th Mar 2013 10:02pm
tookaphotoof wrote:
(1) apart from the fact you guys did post a link of some Swiss company selling front panels for a million Francs? Mr. Green
(2) And a bit off topic, but where f*** can I find the bloody OBD port?
(1) Yes, that is an issue. The standard dash is very expensive as is and 2DIN cost even more often or not. Making the savings in cost of "all the extra boxes" even out between both of them. They are simply two different versions that do the same job. Basically just with one with a static screen and the other with a motorized hidden screen.
(2) The OBD port is behind the access panel under the steering wheel. Thumbs Up Next to the fuses. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #223310 29th Mar 2013 10:09pm
tookaphotoof
Really have to think about this one. The panel might be expensive, but I actually bought the car to never let it go again.
Unless Landrover is still making exactly the same Defender 10 years from now. I doubt it though.
In that case I think my obd port is at the passenger side, just like the handle to unlock the bonnet. Very Happy
Post #223361 30th Mar 2013 7:32am
it could well be on a LHD. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #223393 30th Mar 2013 10:36am
Cable leaves the cabin via a purpose made hole in the bulkhead with a plastic gland and 'tube', this is secured along the chassis and currently comes up behind the rear light cluster
Post #223397 30th Mar 2013 10:56am
tookaphotoof
Found the OBD, missed the panel on the left side. It was underneath it. The panel on the right hand side had nothing hidden behind it. Too bad there was so little space as I was planning on connecting the Garmin Bluetooth dongle to work with my satnav screen.
Have to prepare to leave, but I'll have a look at the bulkhead as soon as I get back.
Post #223490 30th Mar 2013 7:09pm
rrdefender
Norway 2010 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Order this one from dynamic sounds in London. Expensive but as mention above I will have this car for a long time too.
Post #226870 13th Apr 2013 4:19pm
tookaphotoof
Back in Holland.
So ready to start thinking about the Defender again. Cool
I'll probably going to order one of those as like you, I intend to keep the Defender for a long time. This way the interior looks a bit nicer. Must be worth something. Thumbs Up
Now, I just have to decide between matt or piano black. Mr. Green
edit: decided on the matt black version. Smile
Post #228075 17th Apr 2013 10:46am
Page 2 of 3 <123>
