![]() | Home > Puma (Tdci) > a few things ? |
| double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573
had a big pile of fine silty mud get in my altinator and the light stayed on until LR warrenty changed it.
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
Are you sure the squeal is from the turbo? Could it be the drive belt that is loose, thats also causing your charging issues
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
Drive belts have a sring loader tensioner which keeps the drive belt tensioned perfectly from tdi to Puma. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Yes they do
Maybe on a million miler Tdi but not a TD5 or Puma? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Had mine changed at 12k on the Puma
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
Got to be worth a check hasn't it, cheap and easy fix if it is
110 HCPU Tipper |
Yip.. for sure!! I have a BMW with "efficient dynamics" which among other things has the stop/start feature but it hasn't worked since october... called BMW and there was a list as long as my arm for the stop/start to stop working... if the battery is not in full charge and under +4 degrees and if you ar running a lot of electrics. I then asked if the alternator was not up to keeping up and he said a big capacity alternator would use more fuel. I give up. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
its deffo the turbo im 100%
and how did LR do the alternator my light doesnt stay on all the time only ifi get mud init but then it clears itself steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406
from 300 tdi they had them. 200tdi didn't. bearings in them collapse anyway. i had one go on a td5. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505
I know of plenty of TD5`s that had to have the tensioner changed and not a million miles |
LR did the alternator because even after 15 min with a jet wash aimed at the altinator and 150 nervous mile drive home the light was still on, i have to admit and don't tell LR, that i gave the defender the clean of its life an told them it was a road side puddle...........but sssssssssssss i didn't tell you that. |
