Home > In Car Electronics > earth
driveover
England 2002 Defender 110 300 Tdi SW Alpine White
earth
head and side lights, screen washer non-op. checked fuses and switches OK, points to earth no.2, ref. Haynes manual. Anyone know where it is? Would save time rewiring, getting too old to be lying outdoors in this weather! Thanks. My Landy is an export LHD model so does not fit usual specs for year.
Post #222276 26th Mar 2013 1:01pm
I would have had the info in a workshop manual if it was a Puma 2007 > But I notice yours is earlier so cannot help I'm afraid. Confused _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #222284 26th Mar 2013 1:43pm
smb
Where did you get your workshop manual for the Puma from?
cheers
Post #222333 26th Mar 2013 4:25pm
smb
cheers
Post #222334 26th Mar 2013 4:25pm
cheers
Another forum user. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #222341 26th Mar 2013 4:47pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
cheers
PM sent! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #222740 27th Mar 2013 11:16pm
smb
Shax wrote:
cheers
PM sent!
Paul,
You're a god Bow down Bow down Bow down
That will keep me busy reading over Easter......
Thankyou
Steve
Post #222802 28th Mar 2013 9:49am
It always comes in useful. Thumbs Up I would have sent you a copy but I wasn't quite sure how to go about it so I knew someone else would be able to E-mail it instead (I assume) mine's on CD. (Many thanks to Blackwolf Thumbs Up ) _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #222836 28th Mar 2013 11:32am
smb
That ok. I appreciate the thought Thumbs Up
Post #222875 28th Mar 2013 1:40pm
dgardel
Italy
http://sdrv.ms/X3rx3k Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #223089 29th Mar 2013 1:14am
driveover
Cheers Steve, at least some guys got to find Puma manuals! My Landy is an export LHD model so does not fit usual specs for year.
Post #223778 1st Apr 2013 6:11am
smb
Why not look through the Puma manual in case what you are looking for is similar. Surely it can't do any harm!
Post #224534 4th Apr 2013 10:59am
smb
Post #224535 4th Apr 2013 10:59am
driveover - Question
SMB - I agree worth a look anyway.
On a different note why would it need to be a re-wire job anyway unless there was damage to the circuit wiring it's self? I'd have got the Multimeter out and done some all out electrical checking to try and diagnose the actual fault. Manuals are all very well in telling you this and that but ultimately it will still need the fault(s) identifying and diagnosing and fixing. I'd trace the earths back to where they originate and go from there as they are probably going to the same place seeing as it's more than one item. Probably an easy fix in the end. Maybe also worth checking what doesn't work by hardwiring it temporarily just to check that the non OP items are actually still functioning (You've probably already done that) Your near me in Bath so perhaps I can have a look at it for you too if you like? (Couldn't guarantee an instant fix all the same though)
Smile _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #224541 4th Apr 2013 11:11am
driveover
thanks steve 90 I'll try to organise something next week. Should make a change! My Landy is an export LHD model so does not fit usual specs for year.
Post #227043 14th Apr 2013 6:55am
