Home > Technical > DIFFLOCK - can't engage
MUF
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Just wondered if there are any tricks on engaging DIFF-LOCK?
Mine wont go in at all, lever goes across fine and light on dash illuminates but def NO LOCK.
Am I missing a trick before she goes back to the dealer?
PUMA 90
Never used DIFF-LOCK before
Been stuck a couple of times in the deep stuff..
Big Cry Big Cry Love in this order; Burnley FC, Defender, Kids, Wife, LOL
Post #22205 15th Jan 2010 11:33pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Out of interest how are you testing wether it's in or not Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22214 16th Jan 2010 9:10am
MUF
"Wheels on the offside not moving at all, and turning circle is just the same as normal!"
When I use the diff on the rear axle on my tractor unit there is a noticeable difference in handling when turning!
Confused Love in this order; Burnley FC, Defender, Kids, Wife, LOL
Post #22217 16th Jan 2010 11:10am
willy eckerslike
Thats sounds right, when you engage difflock it only locks the centre diff not the axle diffs.
For instance driving up a slippy slope without difflock you could grind to a halt with one spinning.
Driving up a slippy slope with difflock in then when you grind to a halt 2 wheels will be spinning one on each axle.
I wouldn't recomend driving with the difflock in on grippy surfaces as you could damage it specially when trying to turn..
You could put the difflock in and get someone to drive round you on a gravel surface you should see or hear the inside wheel scrabble as it catches up with the outer wheel which is travelling further.
If you know all this already then I apologise Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22218 16th Jan 2010 11:30am
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
It is a great sight to see one wheel on each axle turn nicely up in the air, when the ones that should be turning to get the vehicle unstuck are motionless.
Also a bit frustrating when you call a friend for advice and you're being told: "did you lock the dif? That should do it!". Well, NO! Evil or Very Mad
Pretty useless really. The Mercedes G class has the 3 dif locks. Now to get that one stuck, that must be pretty hard! Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #22219 16th Jan 2010 11:48am
willy eckerslike
The mercedes needs them because it has nowhere near the axle articulation that the Land Rover relies on Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22220 16th Jan 2010 12:16pm
AndrewS
The diff lock is a centre diff lock in the transfer box. When locked it forces 50% of the drive forwards and 50% to the rear. When the drive gets to the front or rear axles it then splits 25% to each wheel. This is the case when the traction is equal for all wheels. If you jack one of the front and one of the rear wheels off the ground the vehicle will not drive away even with the centre diff locked.
Post #22223 16th Jan 2010 2:11pm
jamesbond007
Yes, as illustrated above. Boldly going nowhere
Post #22224 16th Jan 2010 2:21pm
RED-DOT
The G wagwn and Toyota Amazon are the only vehicles with 4 wheel lock up as standard and will go places a Defender can only dream of.. i had a Gwagen and rue the day i sold it.. twice the vehicle of any LR. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #22228 16th Jan 2010 3:10pm
willy eckerslike
Censored  Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22229 16th Jan 2010 3:16pm
jamesbond007
I know, but 3 or 4 times the price! Boldly going nowhere
Post #22230 16th Jan 2010 3:22pm
Glynparry25
I have had them up against each other in the flesh and that statement is a load of old coblers....and why not save the £20K on the price of the production vehicle and spend either £3K on KAM lockers front and rear or £1K on ARB Lockers front and rear which will make the LR a WAY more capable vehicle.
Last time I checked the only people who drive the G-wagons are either:
a. Germans.....you will never find a German willlingly driving something other than a German car.
b. People with too much money who want a 4x4 and a AMG badge.
Glyn
Post #22232 16th Jan 2010 3:58pm
willy eckerslike
If someone offered me either an Amazon or a D4 I know which one I would pick personally. Just have a look at AndrewS's gallery on Disco3 site to see what a D3 or 4 is capable of.
Or should it be up against a TDV8 Range Rover. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22233 16th Jan 2010 4:06pm
MUF
So there I am expecting all four wheels to lock down..
The odds are it's fine then or is there a final check I can do?
Bow down Love in this order; Burnley FC, Defender, Kids, Wife, LOL
Post #22237 16th Jan 2010 4:52pm
willy eckerslike
I think it,s fine mate. You could do the test I suggested or if you can put two front or two rear wheels on rollers, without difflock the two wheels on the rollers will rotate, stop engage the difflock and it should drive off the rollers Thumbs Up
Do a bit of research on aftermarket locking diffs Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22238 16th Jan 2010 4:59pm
