Home > Off Topic > sds drill
slick75
Wales 2008 Defender 90 Puma 2.4 HT Stornoway Grey
sds drill
does any body use an sds drill with good chisel action, can you recommend one under the 100 quid mark ta 08 def 90 ht stornaway grey
Post #222191 25th Mar 2013 11:34pm
mcma1
Cordless??
Post #222193 25th Mar 2013 11:43pm
slick75
sds drill
sorry should of said corded 08 def 90 ht stornaway grey
Post #222194 25th Mar 2013 11:44pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
It depends on what you want it to do, my Bosch was around £300 when I got it a few years ago and it's ok. I used a proper kango (small one) a few weeks to break up some concrete and it didn't touch it, faithful sledge was my friend then! Darren
Post #222197 25th Mar 2013 11:58pm
slick75
mainly for drilling concrete and light chisel work , to hard a job for my standard bosch 08 def 90 ht stornaway grey
Post #222203 26th Mar 2013 12:12am
WarPig
Hire one out?
Post #222210 26th Mar 2013 1:06am
Not for that price! Did you miss off a zero? If you meant under a grand you could buy a decent one! Laughing
If your limit is £100 anything you get will be made of cheese. Expect to pay £500 to £800 for a good one.
Post #222240 26th Mar 2013 9:25am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I have a Ryobi SDS drill - only done light work but pleased with it thus far. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #222244 26th Mar 2013 9:29am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
You can get 2kg SDS percussion drills for under a £100, look for DeWalt or Bosch. If you can stretch to £150 look at Makita. I bought a Makita ten years ago on the recommendation of a local hire company who stocked them on account of the abuse they received on hire. Has certainly lived up to the claims.
Post #222245 26th Mar 2013 9:34am
slick75
ref the 100 quid dewalt or bosch any body have any experiance with these ,would like it to last more than a few jobs ta 08 def 90 ht stornaway grey
Post #222263 26th Mar 2013 11:01am
barbel jim
Bosch all the way. As long as its blue it will have 3 year warranty with it. I have a 2kg 800w for general building work, that has seen plenty of action.Think it was about £120 a few years ago. Find makita very overrated my second choice would be Dewalt.
Post #222269 26th Mar 2013 11:30am
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
Post #222448 26th Mar 2013 9:47pm
bell-auto-services
I have both the Makita drills in the above link and find them very good, I have had no problem getting spare parts when I have broken them which inculde new gearboxes and dog clutches inside. Mine have had some stick over the years and are still going strong.
They dont like "core" drills like used for drain pipes etc as they are just to big for the gearbox barings inside and eventually fall apart from the hammer action vibrating them to death while trying to turn a large drill bit. I use only up to about 24mm in mine as a rule and they are fine even with a 600mm drill length.
Pete
Post #222471 26th Mar 2013 11:02pm
slick75
thanks for the feed back gents .i went for the makita Thumbs Up 08 def 90 ht stornaway grey
Post #222698 27th Mar 2013 9:52pm
