Home > Technical > Handbrake Grip |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Don't remove it Tim, the gator will pull over it
25th Mar 2013 3:46pm |
On my 2.4 under the carpet there are two platic retaining clips/buttons one either side of the lever base on the bulkhead that needs to be removed to facilitate the removal of the gaiter. Once removed/pulled back the whole lever removal is evident. All in all about 15-20 minutes toil. As stated the gaitor will pull over the grip. If you go through life with your head in the sand....all people will see is an ar5e!!
25th Mar 2013 3:49pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
Thanks Guys... Re Fitted my cubby box lid... What a difference.... Sooooooo much nicer and so well made.... I can see a pair of the FCX leather sunvisors on the horizon.....
Which will please the missus no end.... lol It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
25th Mar 2013 8:14pm |
I'm so glad you're pleased
However, you know the forum rules, we want pictures ! |
25th Mar 2013 8:50pm |
