Home > Puma (Tdci) > puma starting problems
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
has anyone had any starting problems with theres as mine is driving me mad got a bad intermitant fault has been into m=the dealers 4 times now Evil or Very Mad with the same fault when you go to start it it turns over for a split second and then throws the starter in and out sounds terrible somtimes grindes on the flywheel it will do this maybe for 2 mins or sometimes 15 mins then all the lights on the dash will flash and wont urn over at all and all the rellays are clicking , once you do get it going it will dive down the road and cut out then might be fine for 3 days Evil or Very Mad
to date for this one fault its had some sort of ecu download
a new starter
and a battery
any ideas
Post #19353 2nd Dec 2009 11:02pm
Grockle
Re: puma starting problems
a new starter
and a battery
any ideas
immobilizer fault 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #19355 2nd Dec 2009 11:47pm
AndrewS
If they have changed the starter try the Earth or Negative cable from the battery to the chassis. Or it could be a damaged starter ring gear on the fly wheel. If the dealer ain't fixed it give it back to them. Get a replacement like for like vehicle until its fixed Thumbs Up
Post #19359 3rd Dec 2009 5:59am
simonpuma90
I was thinking ring gear myself Thumbs Up
well it back there now and im in a 59 3.0l v6 rr sport so all is good
Post #19370 3rd Dec 2009 10:16am
Did you get to the bottom of this in the end?
Mine '07 Puma has what sounds like a similar problem, which started as a very infrequent intermittent fault but is getting more frequent (now happens about 3 times a week).
When cranking the engine to start it sounds as if the starter is jumping in an out of mesh - horrible destructive noise. Sometimes turning the key back to the fully off position and then retrying is OK, sometimes it will do it two or three times in quick succession.
I haven't noticed any indication from the dash lights, they seem normal.
I am thinking perhaps ignition switch, battery, starter motor, starter solenoid or possibly immobiliser? Are there any other relays involved in the circuit?
Any suggestions, or suggestions for troubleshooting? It is out of warranty hence I really need to sort this myself.
Thanks!
Post #81964 26th Jul 2011 8:25am
nickhodgson
Hi
There was a fault with some of the early ignition switches that lead to multiple starter motor failure. I wonder if your problem is a version of this fault. The revised ignition switches have a key with a much bigger black plastic bit where your fingers grip.
Your problem does sound like a loose positive to the starter or a loose earth to the battery/gearbox. I have had my negative battery terminal work loose and fall off leading to a non start.
Nick
Post #81971 26th Jul 2011 9:45am
MK
Mine had it. Fixed witha good earth point and F tight baterry terminal 8you can put a bit if copper wire between the battery terminal and the Negative bracket Thumbs Up Puma 110" SW
Post #81981 26th Jul 2011 10:55am
Thanks Nick,
I did wonder about the switch, and it should be one of the cheaper things to swap out (apart from the hassle of getting the old one off).
It is unlikely to be a loose earth connection, since I ran an extra (rather massive) earth cable from the battery to the winch mount. Positive is a possibility, or the energising feed to the solenoid.
The fact that the 'ignition' switch is a Lucas item desighned in the early 1970's makes it a prime suspect!
Post #81982 26th Jul 2011 10:55am
As MK said above. I had alot of starting and imobiliser trouble and found out that with was due to one of the battery terminals being loose. Slight tightening and light tap of a hammer on the battery post / termainl and all was well Laughing
Post #82021 26th Jul 2011 4:19pm
karlkarl
Sweden 2006 Defender 110 Puma 2.4 SW Chawton White
Hi all,
Mine has this exact problem, although it seems to get worse when its cold and it starts absolutely fine after 2-3 cycles of turning key and trying to crank, getting awful noise and turning key back to pos 1.
Can this indicate that new glowplugs needs fitting?
130k -07 110SW
Post #221155 22nd Mar 2013 3:16pm
karlkarl
130k kilometer that is. About 8000miles.
Post #221156 22nd Mar 2013 3:19pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Mine recenty had a no power situation from the battery at all. Initially thought it was from the battery terminals but apperently it was from one of the loosen wires to the relay box under the driver's seat! Then tightned with a srew driver and job done! Very Happy Very Happy
Post #221174 22nd Mar 2013 4:18pm
Eduardo
Battery terminal loose appear to be a common problem Sad .
Mine had the same problem sometimes, in special after a rough road driving. Im willing to change the terminal for a better one or use the MK alternative.
Cheers Eduardo
Post #221184 22nd Mar 2013 4:52pm
