![]() | Home > Puma (Tdci) > Help - Front interior light fuse/ |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
under the dash mate, does your radio still work as the front light should share the same fuse
![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
If your putting led lights/bulbs in I think they have to be fitted the correct way around or they won't work.
DAZ is correct ![]() If the light does not work and no blown fuse then take the bulb out and put it in the other way round. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
Chris, radio still works.
DAZ, good thinking, and something I neglected to check. just been outside to have a look, switched the light off to ensure I didn't accidently short it again, swapped the connections around but no joy, looked around to check on the other light in the back and that one wasn't on either. I know it has been working because I have been having to reach behind me to turn it on when I want to find something in the dark. anyway, started putting the front cover back on and the light has come on but very dimly. suspect it is a bad earth somewhere but not sure where to look. |
Just fitted lit sun visors and had to have the assembly out. There are two earthing points - one is black cable/connector going to the metal backplate on the inside of the headliner, and the other is the right hand nut that clamps/earths the light assembly to the back plate through the headliner. Perhaps check both - and the live connector (purple wires).
Forgot to mention - make sure you remove the fuse before unmounting the light assy - there are bare (permanent) live rails on the backside which will blow the fuse if (or rather when ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
