Home > Technical > NO POWER
merebrowpaul
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
NO POWER
Any ideas ? I was pulling away from a round-a-bout my 09 90 lost all power and the engine noise sounded like a bag of spanners i limped on to the hard shoulder there is a picture of an engine on the dash so i turned it off. after 10 mins turned it back on and went fine again but the light is still on. The engine was not fully up to temp when this happened do i need to go to a dealer to get the light turned off Sad
Post #22067 14th Jan 2010 8:26am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Do not panic, it happens too us all, you need Q058V5 update to your software, take it in and tell the dealer what happened and he will put the software patch on. The car will be fine and the light will go out after a while.
Most people have had this generally before the car get fully warm Thumbs Up Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22068 14th Jan 2010 8:47am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Dunno if that is the same (the MIL and lost of power can have multiple causes, so better take your car to the dealer to check what is the actual error code), but just in case, did you check these posts?
http://www.defender2.net/forum/topic1834.html
http://www.defender2.net/forum/topic2333.html
http://www.defender2.net/forum/topic2288.html
Post #22069 14th Jan 2010 8:49am
AndrewS
Easiest way is to call Land Rover Assist and get a Land Rover Tech to come out (not AA) Get them to check the car over. They will recommend a visit to the dealers if required. If its un drivable or not safe to drive the car will be collected and you will/should be given a Land Rover product whilst yours is being repaired.
Post #22071 14th Jan 2010 10:00am
merebrowpaul
cheers guys 90 now in dealers getting sorted will keep you informed
Post #22079 14th Jan 2010 12:34pm
merebrowpaul
Got my 90 back it was what you all said it was but all sorted now not much different it seems a bit smoother just glad it was nothing to serious thanks again
Post #22184 15th Jan 2010 4:45pm
