Home > Maintenance & Modifications > What Suspension set up
Jez676
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Im after a fast road handling set up for my defender 90 station wagon. i don't do any off road and im looking for a better handling on a and b roads. I believe I need thicker anti roll bars, shorter springs and different dampers I've looked on the old posts but there is no definitive answer to which is the best set up as most of it goes to PM's.
JE are £1600 plus the dreaded. Is there a cheaper and reliable alternative?
Sorry to upset the off road purists Whistle
Cheers Jez
Post #219748 17th Mar 2013 12:01am
Glynparry25
You are hereby banished from the Land Rover world!....... 'Don't off-road', disgusting Rolling Eyes Razz
Speak to any/ all of the tuning companies out there:
Alive.
BAS.
JE.
CSK (Sure he can point you in the right direction).
and there are a few others too. I am sure they will all say they do the best kit but all depends on budget etc. I am sure if you bought your own springs and shocks which will really convert the drive will be WAY less than £1600+. For that price you are probably talking race-spec for a high power car like the ZULU (Which by coincidence I saw the film ZULU yesterday after the Wales rugby game).
Good luck with the hunt and keep us all posted with pictures Thumbs Up
Glyn Dog Sheep
Post #219757 17th Mar 2013 5:37am
Jez676
Forget all this Les Miserables namby pamby stuff, when they start to sing Men of Harlech at the end of Zulu, man tears come out Big Cry Big Cry
I'm really after some feedback from somebody that has bought a set up from one of the tuners. I know it's not a race car but I live in rural Devon and its twisty and bumpy roads. Your either banging your head off the top of the door or its so bouncy in trying to turn the radio up you end up poking some random place on the dashboard!
Just want something to make it roll and pitch less on the road. My budget is nowhere near £1600 but I'm hoping to offset some of the cost by selling the standard set up as the car had only done 500 miles from new.
Maybe one of the tuner boys who reads the forums could do me a deal? Rolling Eyes
Post #219801 17th Mar 2013 9:58am
Glynparry25
Rolling with laughter Rolling with laughter Rolling with laughter
I have done the poking the dash many a time- then the missus looks at me as though I am drunk and can't do simple tasks like press a switch!
Just had a quick look on the Alive site and a full setup (Springs and shocks) come to about £700 + VAT. Plus they (as the other sponsors) tend to give a discount to D2 members..
Just getting set of shocks and springs that are matched will make a huge difference rather than the over-dampened LR setup.
Glyn Dog Sheep
Post #219808 17th Mar 2013 10:17am
Jez676
Just had a look on the Alive site yes it's more affordable. They are selling bilstein dampers but on here Koni seam to be favoured.whats the difference?
What would be really good for me is an idiots guide to what's good and bad and why??
Post #219812 17th Mar 2013 10:48am
Glynparry25
It is all about matching spring rates and damping rates..... I learnt a lot about it when I was into fast cars, but it isn't quite the same when dealing with a heavy garden shed on wheels.
I run OME and Koni- it is an awesome setup... but it is for off-road and overland- so might not suit your needs as much. LR for some reason over dampen which causes the 'choppy' ride.
Maybe speak to a few of the companies and ask them why they have the setup they sell- Unfortunately the nature of the beast means there are 1 million companies making off-road suspension but only a few make on-road suspension for Defenders which limits choice and keeps the prices high.
Also consider what load you carry and whether you tow- it will all affect the setup you need
Glyn Dog Sheep
Post #219816 17th Mar 2013 11:09am
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
The JE set up is for their Zulus, i.e. fast road. Konis, softer and shorter springs, and stiffer anti-roll bars.
http://portal.jeengineering.co.uk/defender...sion.html.
Post #220125 18th Mar 2013 9:07am
Jez676
Has anybody on here got the JE set up? Does it make a big difference?
Post #220213 18th Mar 2013 4:01pm
barbel jim
It all makes a difference, but bear in mind you don't have a 110 with a larger twin turbo'd engine. Reading other post on Koni, seems to suggest they work better off road and when carrying loads. Bilstein have also been an established name for years and tend to appear more on the faster road orientated defenders. I have no experience of either. As Glyn suggested speak to Gary at Alive, he built a TD5 racer. Thumbs Up
Post #220215 18th Mar 2013 4:13pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
[quote="barbel Reading other post on Koni, seems to suggest they work better off road and when carrying loads. Thumbs Up[/quote]
Again, like mentioned on the other thread, there are 2 types of Koni shocks. The Koni Heavy Track RAID are shorter and designed for performance on roads/rally tracks, might well be a good solution for the OP, but would need to choose appropriate springs to match. Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #220217 18th Mar 2013 4:22pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
For me I use standard LR road springs, Koni and an Alive uprated rear anti roll bar with super pro bushes. It will now hustle along very well and I am a 'progressive' driver when conditions allow. ....
And the ride is very good as well BM52
Post #220219 18th Mar 2013 4:24pm
Jez676
That sounds an ideal solution not changing the springs saves a fortune!
What is the actual advantage of the shorter springs? Does it improve things significantly?
Post #220252 18th Mar 2013 6:35pm
SGH
Koni Raid and standard springs on my 130 with OME steering damper..
Post #220262 18th Mar 2013 7:05pm
Morepower
New Zealand
I've just today fitted the Alive 'Kit" Bilstein Dampers, Lowering Springs (Although I might have the wrong front springs - Waiting fo Gary to come back to me)... Alive rear rollbar and castor offset bushes (Not fitted the Castor Correction yet).... All I can say so far... Is what a difference... Handles far less truck like... Can't wait to sort the Castor and Check the tracking... Although I think the fronts too low at the moment... (see above)
Cheers Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #220277 18th Mar 2013 7:32pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
If you don't want to lower it I know where you can get some standard figment fox shocks Wink 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #220304 18th Mar 2013 8:41pm
