Home > Maintenance & Modifications > Koni gas shocks
keith
Koni gas shocks
The general consensus is that Koni gas shocks are the best replacement for the factory fitted ones . I'm aboot to fit front and back as my springs are coming off anyway to put ma 2" lift on (2.2 110 csw xs). Where's best to buy as eBay is £400 for 2 which seems daft and paddocks are £80 ? Cheers .Keith
Post #219370 15th Mar 2013 9:41pm
Litch
I researched this at the end of last year as I was replacing my DC gas shocks (which had served me very well).
As you have noticed, Paddock are quite significantly cheaper than just about anywhere else however Flat-Dog also sell them at the same price and also have free P&P but the deciding factor for me was that they both have additional discount codes on Facebook and on the day I was ordering it was Paddock who had a valid code so I ordered from them.
As for the shocks themselves I have been a little underwhelmed but I think that is my fault as I changed the springs at the same time and the front ones are just too stiff (I like a firm ride but this is stupid). I knew they were too firm when I was fitting them but thought I could get used to it but with no additional weight up front (winch etc) they barely move at all so some softer ones are sitting here ready to go on which should let the shocks show what they can do. ONE LIFE, GET IT!
Post #219381 15th Mar 2013 10:05pm
keith
so which model of koni did you use ? I'm gonna be putting a +2" shock on . Using the same original springs .
Post #219385 15th Mar 2013 10:14pm
Litch
Standard height Heavy Track. ONE LIFE, GET IT!
Post #219390 15th Mar 2013 10:39pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
When checking prices make sure you are comparing like for like -
ie. there are 2 versions of the Koni's
Heavy Track - heavy duty, adjustable, designed for 4x4 utility loads on mixed surfaces ie. expedition / general work - priced £60-80 ish
Heavy Track Raid, still heavy duty but designed for less weights and performance speed work ie. 'rally raid' - priced £160 ish -
If you are looking for good general purpose shocks, with or without heavy loads, then you want the cheaper one - not the Raid Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #219402 15th Mar 2013 11:01pm
keith
wow 5 star info thanks . Iv used other gas makes before and excellent results , I'd just like a change and try the koni , cheers .
Post #219413 15th Mar 2013 11:11pm
DAZ110
Try Devon4x4
Post #219441 16th Mar 2013 12:07am
mikeh501
I bought a set from flat dog last year. About £50 each. Be aware though they are very hard for road use. Fantastic off road though.
Post #219461 16th Mar 2013 8:26am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
If the Koni's are adjustable - what are the available settings? Can they be made "softer" for more road user for example?
Post #219464 16th Mar 2013 8:50am
The current price for Heavy Tracks (not Raids) on Paddocks website is £91.80 each, inc. VAT. Flatdog are slightly more. Paddocks offer free delivery for orders over £100, which is worth bearing in mind.
I bought two of mine from site sponsor, Defenderbits, which was slightly cheaper than Paddocks, but only as I was able to go and collect. I was lucky enough to pick the other two up at a bargain price from eBay.
I don't recognise the description of them being too hard for road use. Mine are absolutely fine and a big improvement over the originals. It does depend on the setting though. When I had them on an expedition prepped Disco I they were set soft on the front and hard on the rear, which did tend to be a bit firm when empty. On my current 110 I have them set soft all round, although I'm considering changing the rear to medium as a compromise for towing.
There are three settings available: soft, medium and hard. To change the setting a collar has to be twisted on the body of the shock, for which it really needs to be removed. Darren
Post #219477 16th Mar 2013 10:02am
K9F
DAZ110 wrote:
Try Devon4x4
Good call Daz.....
Devon 4X4 are offering a 25% off voucher in their March newsletter on Koni shocks until 31/03/13..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #219479 16th Mar 2013 10:11am
mikeh501
K9F wrote:
DAZ110 wrote:
Try Devon4x4
Good call Daz.....
I guess that will make up for them being nearly 100% more expensive than other retailers lol. Laughing
Flatdog are selling them at £59.99 each for standard height and £70 for the +2's
http://www.flatdoguk.com/koni-heavy-track-std-height~504
To answer the question of how hard they are... I guess this can only ever be anecdotal given every land rover has different equipment etc, but on :mine: Which is a 90 hard top with nothing in the rear, but does have winch bumper, rock sliders and receiver etc. The springs are flatdog std height, std weight springs. the ride as follows:-
* When the dampers are cold the ride can pitch a little front to back as though its just a little over damped. Its not uncomfortable, but could be better.
* Off road the dampers are excellent with great articulation, damping on drops etc. Cant fault them at all off road.
* Once they have been given a proper work out off road (which my truck spends 90% of its life) then are much much more supple when back on the road, and the ride is excellent.
To sum up, if you were carrying more weight like an expedition vehicle or loaded up 110 then i can imagine they are pretty supple. if your not carrying a lot of weight they are definately overdamped on road, and if thats all you do then its just OK.
Just bear in mind as above that you can only adjust them when removed from the vehicle. Mine are all set to the softest settings.
good dampers Thumbs Up
Post #219480 16th Mar 2013 10:27am
Mike, the Flatdog prices are plus VAT and are also more expensive for TD5 onwards (the OP has a Puma). Darren
Post #219482 16th Mar 2013 10:35am
mikeh501
fair play, it isnt as big a difference Whistle . the devon4x4 ones still look well overpriced though. Got mine from flatdog and had no issues with them etc. obviously YMMV.
Post #219484 16th Mar 2013 10:45am
Litch
I haven't had cause to play with the settings on mine yet but this is mainly due to the springs being too firm anyway. As soon as the springs are replaced I will have a go.
I did play with the settings before I fitted them but to be perfectly honest couldn't notice any difference however that is hardly a scientific way of doing it so when the softer springs are on I will leave them on the standard setting. After a couple of weeks when I have got used to the characteristics across as many different surfaces as possible I will then try a different setting and see if there is a noticeable difference. ONE LIFE, GET IT!
Post #219510 16th Mar 2013 12:56pm
