Home > In Car Electronics > 90 dash speakers |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19747 |
Are we talking a Puma Defender? And also what speaker size do you have? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
13th Mar 2013 11:11pm |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 |
sorry, its an early 1990 90 defender, they are 4" (100mm) fronts. i've bought the genuine land rover fitting rings, but with the wiper motor behind the n/s speaker, it doesn't look like i can get much in there
13th Mar 2013 11:16pm |
Photo's would be ideal if you could? Also how deep are your adaptor rings shallow one's or deep ones? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
13th Mar 2013 11:27pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Buy 4 lots of spacer rings and fit two per side mate, does the trick and still looks like a factory finish CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
13th Mar 2013 11:33pm |
They are at work, but guessing the rings are only half an inch deep
My old 200tdi thats what i done on that god i miss this motor
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
13th Mar 2013 11:36pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1412 |
Never had a problem with mine on standard LR rings. I'll try and measure the old speakers depth for you tomorrow. Just fitted 130Vrs vocals in mine. They are shallow mount with a tweeter and well worth the money. The tweeter alone will totally change the sound , if I could only do 1 mod to the set up that would be it. I'm sure the 100 mm focal K2 's are a direct fit or the coaxial integrated. Like I say I'll measure tomorrow for you and post some pictures when I'm on the laptop
14th Mar 2013 1:14am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
i can'y remember if i have spacer rings fitted on my 300tdi with infininty speakers; but i know i don't need them on my puma which has 4" rainbow mids fitted
14th Mar 2013 9:58am |
yer the rainbows are pretty shallow aren't they CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
14th Mar 2013 10:00am |
chris - i'll let you give daddy the model number as i can't find my paperwork anywhere
(had the truck rocking to sandstorm by darude on the way to work this morning - epic trance to set the day up |
14th Mar 2013 10:14am |
Try these: http://www.mudstuff.co.uk/products/in-car-...-deep.html A few on that link please check the sizing that you'd require. As you can see there is a deep version. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Mar 2013 12:05pm |
Measurements as promised. Old speakers were 50 mm deep, and fitted without a speaker ring.
I then put the original speaker ring and grill over the top to retain the factory finish.These rings are made on a slant which measures 15mm narrowest and 22mm at the widest point. So using these rings potentially you could get a 65mm deep speaker in no worries. Heres a bad picture but will give you an idea Click image to enlarge I have recently upgraded to 130 (5") focal VRS which are 48.5mm deep and again fit without speaker rings. They are infact a tighter fit on drivers side. Click image to enlarge better sound due to larger cone,and are a tight fit. Biggest advantage is the addition of the tweeter which lifts the sound stage. Here is a picture showing what is behind that end cap. It is realativly easy to remove 4/5 screws then pull out and down. It has a couple of locating dowls. Click image to enlarge Hope all that helps |
14th Mar 2013 3:25pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3467 |
where can i get the spacers from? 1951 80" S1 2.0
19th Mar 2013 2:59pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
MUD sell them
19th Mar 2013 3:42pm |
