![]() | Home > Maintenance & Modifications > Noise killer |
yorky Member Since: 25 Aug 2012 Location: West Yorkshire Posts: 119 ![]() ![]() ![]() |
Sounds good, what sort of price? 90 XS
Volvo V70 |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I had Noisekiller complete set in my 90, but have taken out most of it and repalced it with Dynamat as I was fed up of the Noisekiller stuff getting wet and never drying out as it is a sponge.
It is good stuff though in terms of supressing sound and vibration. Would be great if you don't get your defender wet. |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
I would imagine it would not be good if wet.
I think it makes a massive difference to road noise . Still will like a bit less from engine bay ? |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
That is one of the biggest problems. To try and make a difference I completely covered the underneath of the hood in Dynamat Extreme, filled the cavities with expansion foam(really messy job) and put a lead blanket(from NoiseKiller) on the engine. It has made a massive difference. However, I used a sound meter(db reader) all around the outside of the engine bay and found a big problem was the gap between the top of the wings and the hood when closed. I am trying to find a decent rubber(waterproof) channel to go around this and as soon as I find a good one I will let you know. Oh, and if you decide to have a go at the above, start the job on a Friday night and leave it for 24 hours before you finish it. And take your bonnet OFF as it makes it a lot easier. The drawback to the above is that it quietens everything(which is very good), BUT in doing so makes you realise how much wind noise comes from the top of the windscreen. But then, what can we expect when the aerodynamics are of a brick. Hope this helps. Steve |
SMB - I use the rear door seal sold by the metre to clip down both sides of the bonnet and it works a treat. MM4x4 and similar sell it and it is not much per metre so an easy and cheap solution.
That's brilliant! ![]() ![]() Thanks |
That sounds really good any pics of finished article?
In fairness mine sounds really quiet from outside the car. It just seems noise through the bulkhead area , I think ![]() |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Hilti expanding foam is far far better to use, it doesn't have the silly expansion that some foams have and is much more manageable to use and clean off your hands
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
I like these ideas as I don't like noise from my new 2.2 Considering the bonnet sealing, sounds fantastic, has anyone with this noticed if it affects the cooling air flow and engine temperature?
Frosts.co.uk do 3 sorts of rubber sealing strip, might be worth a look
I think the noise blanket and insulation make a massive difference. Still would like to improve the bulkhead nose.
No heat problems , it has been rather cold though. |
