Home > Td5 > Coolant leak..
whelo
Wales
Coolant leak..
Hi, been topping up the coolant for couple weeks, not much to warrant panic.
Climbed under her this morning to change the reverse light switch & noticed red coolant on passenger side of sump..
Opened bonnet & under turbo there was the coolant pooling..
I couldn't see where its coming from, looks like i'll have to take off the manifold to see it, any idea's where they leak in this area..
Cheers, Jason Getting there, slowly..
Post #218636 13th Mar 2013 3:33pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
yep is it at the back of the engine ?
if it is im afraid its time to do a head gasket what year is the car and at what miles ?
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #218639 13th Mar 2013 3:45pm
whelo
Wales
2002 & 92000... Getting there, slowly..
Post #218642 13th Mar 2013 3:49pm
big steve
is it at the back under number 4and 5 on the manifold ?
stev 2015 2.2 tdci hardtop xs
Post #218644 13th Mar 2013 3:54pm
whelo
Wales
Sounds about right, can't really see where its coming from, i haven't got any normal head gasket signs.
She's fine apart from the topping up of water every now & then..
Post #218647 13th Mar 2013 3:59pm
Under the turbo is the oil cooler, which has a pipe coming off it for the heater, that could be weeping, or the oil cooler housing gasket where it bolts onto the block.
Post #218648 13th Mar 2013 4:10pm
whelo
Wales
Hope its that then, what's the easiest way to access it?
Post #218649 13th Mar 2013 4:11pm
Drain the coolant, turbo & manifold off (easier to leave the turbo bolted to the manifold, just undo the oil feed and drain pipes, careful as there's a gasket on the drain pipe and 2 copper O rings on the top feed)
then you need to take the centrifugal filter off (3x 10mm bolts) then the main oil filter housing (3x 10mm bolts) then you can get to the cooler itself (which is about 6 or so 10mm bolts), all easy. a couple of tin gaskets for the centrifugal filter and main cooler that should be replaced.
Although if you're looking to see if that heater pipe is leaking, just take the turbo heat shield off.
To see if the cooler is leaking, with the turbo heat shield off as well, with a torch you can see behind the turbo.
Post #218657 13th Mar 2013 4:31pm
whelo
Wales
Sounds like a job for the weekend, shame there's rugby on.. Hopefully i wont b too hung over sunday..
Cheers for the help..
Post #218752 13th Mar 2013 9:04pm
Welshsurferdude
Wales
Yeah kick England's arses Wink 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #218755 13th Mar 2013 9:08pm
whelo
Wales
Thumbs Up Getting there, slowly..
Post #218758 13th Mar 2013 9:13pm
landy andy
There is a core plug/big screw in thing, in the side of the head, and these often leak. They don't show it as it dries with the heat of the exhaust, but it gets blown to the back of the engine by the fan, and tracks along the head gasket, giving you worrying wallet twitches.
Will try to find picture.
Andy
Post #218817 13th Mar 2013 10:23pm
landy andy
Between exhaust ports three and four
http://s533.beta.photobucket.com/user/hawk...7.jpg.html
Andy
Post #218824 13th Mar 2013 10:31pm
whelo
Wales
Cheers Andy, looking at your pic its not far off there, it pooling on the flat toward the bellhousing.
Looks like i'm gonna have to take the manifold off anyway to sort it.
Luckily its not leaking that bad, so it can wait til next weekend.
Post #219236 15th Mar 2013 11:48am
mk1collector
I've just discovered the same problem so it's booked in for checking and maybe new head gasket and skim in a couple of weeks Big Cry
Post #219275 15th Mar 2013 3:59pm
