![]() | Home > Maintenance & Modifications > Squeak squeak... |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Use some lithum grease on your clutch spring ![]() |
WD is great for removing oil and grease... as you say works for about 40 mins get some Grease on you're clutch pedal....that should sort it...as for you're seat lose some weight
Reading the post I thought what an opportunity to make a joke about weight! Scrolled down and Fekete my old mucker beat me to it! Must have read my mind!
![]() Treat every day as if it is your last....one day you will be right!! |
Yes we seem to think on the same wavelength...any opportunity...and one of us are on it...you me or willy
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Okay, okay - I get the hint. Time to slim down.
I heard from someone else
![]() 110 HCPU Tipper |
Should the sillicon lube be applied to the seat or the lard 4r5e sat in it? Sent from a not so slim southerner! ![]() Treat every day as if it is your last....one day you will be right!! |
Come on Guys i'm in the 17stone club and mine doesn't Squeak.... how big are you Guys
Was wondering why whenever I get in or out of my Landy there was a loud 'pop.' Will be siliconing my doorseals forthwith!
![]() Anyone know how to spell silikone! Tried several variants now? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Its silicone... Me old Cider Chum NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Once Upon a Time in one of our forces aircraft a mouse had been seen scurrying about. After attempts had been made to trap it with no success it was decided to take the aircraft up to a significant altitude have the crew on breathing air, open the door and let the little bu99er suffocate. And they all lived.......except the mouse that is! The end!
B & Q do a trap for mice, with regards to the altitude bit I think it's a non-starter but maybe a 'phall' at your local Indian followed by a long run may have a similar effect on the little blighter should it happen to be a mouse of course! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Take it to the dealer ![]() I was going to post "Take it to the dealer Fatty" but thought better of it ![]() ![]() |
Me too, but Fekete beat us to it allbeit in a more diplomatic manner! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172 ![]() ![]() ![]() |
When I look at K9F's avatar, I know where the squeak squeak comes from... Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
