![]() | Home > Maintenance & Modifications > Swivel Grease / EP90 |
| Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171
Hi all
I searched a bit to see if this question was already answered but I could not find what I was looking for. I went to check the oil in the swivels on my 1984 110 and found that it was filled with grease. I don't have an easy find for the "one shot" grease to replace this with. Does anyone know if there is a suitable generic replacement that I should be able to find locally here in Canada. Is this some high temp bearing grease or something uber-special? Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
| tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436
Timo,
what I see is that all grease and oil producers do have some type of CV-Grease. Looks as the trick is in added Moby etc etc to withstand pressure and temps better. You should be able to find it locally, guess mentioning Ashcrofts etc have it doesn't help much. Anyway looks as it's nothing exotic, and as EP90 was doing the job for decades on our high performance defenders i guess some mainstream available CV grease will cover your needs. |
Yes it should, and currently does, have EP90 on the one side that I was working on and blew the grease out. From what I remember once grease goes in you can't use EP90 anymore. My assumption is that the PO used grease because the swivels were leaking. Me putting EP90 in it should prove this true or false. Thanks for the info. I will see what I can find locally
p.s. Picked up a Corgi Series I 109 at an antique store today for about 8 quid! Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
| All times are GMT |
