Home > Puma (Tdci) > How waterproof is puma?!?!?!
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Is the ECU of the puma engine is waterproof??
Is there under the bonnet any other eletronics that isn't waterproof??
Post #21791 10th Jan 2010 9:05pm
110SEB
The ECU couldn't be any LESS waterproof. The underseat box that it's in, is NOT waterproof and will let water in eventually.
There are bound to be bits under the bonnet that will not like to be totally submerged.
Depending on what LR you have, you could re-locate the ECU on the roof lining, or on a cargo barrier or something.
I'm sure others will be along soon to give you some advice you can actually use!
Happy swimming!
Post #21793 10th Jan 2010 9:09pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Ive had a bow wave upto the bottom of the windscreen. I have a un-sealed RAI but I beleive the plastic jobby from mantec is more for dust rather than water (unless you use a tube of silicone sealent).
I checked the underseat box straight away and there was a small amount of water but not enough to worry about.
All I can say was that I was particularly stupid and very lucky all in one day!!
Post #21795 10th Jan 2010 9:21pm
Glynparry25
The ECU is no longer located there- they haven't made the Td5 mistake again. It is now located on the bulkhead behind the engine. I would say it is waterproof enough, and to get water there would be a challenge unless you stop in water up to your windscreen.
Glyn
Post #21798 10th Jan 2010 9:35pm
TJ101
The ECU on the Puma, is under the bonnet, bolted onto the bulkhead, behind the cylinder head California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #21799 10th Jan 2010 9:38pm
110SEB
I stand corrected Thumbs Up Whistle Rolling Eyes Embarassed
Post #21801 10th Jan 2010 9:47pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
land rover will tell you that it has been made water proof due to its re-location under the bonnet until you get it full of water and have a fault, then they will tell you that you must have exceeded the waiding limit and they will also not accsept that it could collect water spray from the road, also pointing out to them that your cd player and all the instroments are still working and that they would have been flooded if you had been stationary in that depth of water will not win them over.
as you may have guess'd i'm on the look out for an ECU loom extention.
so no its not water proof.
Post #21809 10th Jan 2010 10:51pm
Gabriel Boff
A LR dealer mecanic tell me that exist an acessory that make the ecu waterproof, do you know something about it???
So, it's sad one LR that can't go underwater if you need, and it's a quite strange, because you can't submerge the Defender , but it submerge you and your bags in every rain!!!
regards
Post #21817 11th Jan 2010 12:36am
dgardel
Italy
Ecu connectors are water proof (I wash several times my engine bay with high pressure washer and I'haven't any problems).....
If water arrive on the ECU, probably it has damage somethings in others car parts....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21833 11th Jan 2010 11:00am
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
I wonder what that ECU look alike box is under the passenger (continental) seat. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #21838 11th Jan 2010 11:48am
Glynparry25
I am sure someone will correct me if wrong but I do belive that is all the ABS/TC gubbins.
Glyn
Post #21849 11th Jan 2010 2:44pm
jst
ABS box is my understanding as ^^^^ Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #21856 11th Jan 2010 3:25pm
jamesbond007
Well, I checked again under the passenger seat (i.e. right hand side here) and there is nothing that looks like an ECU. I have no idea why I had that impression as I have never seen the intimate parts of any Land Rover but the SIIA and the Puma. Rolling Eyes Nothing under the driver's seat either. Too much Portuguese tinto I suppose. Boldly going nowhere
Post #21857 11th Jan 2010 3:39pm
roel
This was the ECU when I bought my Td5.
I still wonder why it didn't start. Whistle Roel
2003 90 Td5 (2009-now)
Post #21890 11th Jan 2010 8:44pm
double cab happy
i cant understand why they cant hard wire it to a long cable that connects to the vehical loom at some high point and have the ecu fill'd with silicon or similare, this would make it very waterproof, and not a great deal more expenceive, other things would need waterproofing but the expencive "brain" would be ok, all that said why can't they just mount it high.
Post #21915 12th Jan 2010 9:15am
