![]() | Home > Maintenance & Modifications > Best lock washers for a turbo manifold? |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Please can someone advise me what's the best type of lock washers for my turbo manifold bolts? Split, ribbed?
The M8 bolts (10.9) have stayed tight for a few days (re-tightened after cooling) but they're always easy to undo I want to make bloody sure they won't come out again before I refit the heat shield. Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Matt,
If it were me and I was concerned about it I would source some bolts that you could wirelock with steel wire as depicted below. Wirelocking is used prolifically in the aviation engineering World..... If you go through life with your head in the sand....all people will see is an ar5e!!
Cheers Mal - looks the biz, but trouble is the three bolt heads are on opposite sides of the flange and rather far apart. It's bloody awkward just getting fingers in to do them up. Might try it as a last resort though
Any "lazy" solutions? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Guy on the Mustang forum just suggested these babies:
http://www.fastenal.com/web/products/detail.ex?sku=0162564 I've looked like hell but can't seem to get them (sent) here But shout it at them in German because life is also terrifying and confusing... |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
As they the same as here? http://www.nord-lock.com/
They've got an address in the UK... An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Yep - the same ones - look serious, don't they
Nord Lock have loads of distributors in Germany but none seem to sell to Joe Public Actually... I tell a lie. If I want to buy 500 (at nearly a Euro each), it's not a problem There are a few online shops in the UK but at first glance they don't ship to Germany. I've E-Mailed a few so fingers crossed (or "thumbs pressed" as they say here). Otherwise I might ask a helpful forum member if they would take delivery in the UK and send them on to me But shout it at them in German because life is also terrifying and confusing... |
Just let me know Matt and I'll do it! You still got the address? Treat every day as if it is your last....one day you will be right!! |
Cheers Mal - yup, I'm sure I have it somewhere
I'll wait a day for E-Mail replies (or lack of) then let you know Steve - that was my original plan but since the dealer has already bolted (studded) it on twice and the LR studs/nuts have kept loosening/falling out (the original ones did too - I've no clue why), I've fitted a Nak gasket and am trying a less conventional approach. It's currently only very slightly leaky (probably warped a bit) but no noise or other symptoms. I decided against using paste - fitted it dry and sod the leaks But shout it at them in German because life is also terrifying and confusing... |
| v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195
i work for a fastener company and we stock nord-lock washers. let me know what you need and i'll see what i can do. should have what you want in stock. if so i'll even post them out to you gratis.(favor owed).
however should you torque these up right and later want to remove them you will have a job on your hands. 110 xs s/wagon s3 swb soft top |
If possible, that would be fantastic
I only actually need 3 washers but I reckon 6 or so would be a good safety margin for me The ones I'm after are Nord Lock NL8 (M It's pretty hard to torque them correctly as you can only get a ring spanner in there. As far as removing them goes, I hope I will never have to... as long as I live But shout it at them in German because life is also terrifying and confusing... |
no probs. i'll have a look tomorrow. and let you know tomorrow night and if in stock you can p.m. your address.
s3 swb soft top |
have washers here ready to be posted if you can pm me your address.
happy to help s3 swb soft top |
Steve, they just arrived
Blimey - they are so cool - serious engineering for washers. No wonder I couldn't get them from the "normal"places... not that you're "abnormal" of course A million thanks May the sun shine forever on your Defender Have a great weekend, Matt p.s. I'll leave feedback on the forum if they work But shout it at them in German because life is also terrifying and confusing... |
They are seriously awesome
When undoing bolts used alone, after you break the stiction they undo without resistance. With the Nord Lock washers, it takes much more effort to start undoing the bolts and even then, they still resist for another 1/2 turn or so. I need to keep an eye on them for a few months but I am seriously impressed. No wonder they're a quid each At least you can re-use them... Cheers all, especially Mal and V8Steve Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
