![]() | Home > Tdi > Bonnet mounted windscreen washers. |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
I have HeatShot installed, as well as the P405 wiper arm washers. The setup clears everything from the screen and puts the washer fluid exactly where it needs to be, using less of it, especially in Winter.
I know mine looks a bit "Heath Robinson" (of whom I an avid fan, as well as Tom Lehrer and Gerard Hoffnung), but so is the whole vehicle. The advantage is that in an emergency I can just pull it off at the front and clip the original nozzles back on. Oh, and I took it through the car wash yesterday (terrifying experience) and everything remained intact But shout it at them in German because life is also terrifying and confusing... |
| roamingman Member Since: 15 Mar 2012 Location: nearly thier Posts: 152
Years ago when I started driving never had washers on car Austin A45 van or lorry Ford Thames Trader, use to cut Apple or potato in half and rub on screen water used to run off.
Showing my age know. Live Life Ti'l You Die Teddys are out thier http://teddybearspicnic.webs.com http://130sasha.co.uk/ |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
hi Mark
here's a link to the pdf so my plan was to use the temperature activated switch powered by an ignition feed (VSR off the aux battery that runs the breather heater) cheers steve http://www.e30zone.net/e30zonewiki/images/...r_jets.PDF |
Aha! One of my worse "windscreen" experiences is when I broke the wiper on my A2 at the airport (didn't bother to clear snow first But shout it at them in German because life is also terrifying and confusing... |
