Home > Tdi > Bonnet mounted windscreen washers.
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Hi guys n girls,
I'm thinking about mounting some windscreen washers on the bonnet, has anyone actually done this, if so do you have any pictures, part numbers etc?
I've done a quick search and found nothing, I'm sure someone will be along shortly to show me that its been asked before though. Very Happy
Any help would be extremely appreciated.
Thanks,
Mark
Post #217181 8th Mar 2013 5:52pm
You'd need a fair angle to get it squirt that high!
Post #217183 8th Mar 2013 5:55pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
It's miles away from the windscreen and the jets of water are likely to be blown off course even more than they are already when driving. Best mod is to fit the jets onto the wiper arms, that way the water is where it's needed, on the screen!
Post #217184 8th Mar 2013 5:56pm
pope10001
The reason I ask is that I've just watched the JE Engineering Zulu video and noticed that they have them mounted. And you can angle the nozzles toward the windscreen. I was thinking about mounting some from a n other vehicle.
Regards,
Mark
Post #217187 8th Mar 2013 5:58pm
pope10001
The only problem I have with mounting them to the wiper blades is that I still haven't seen anyone do it so that it looks as if it could be factory fit. The ones I've seen always look a bit Heath Robinson.
Regards,
Mark
Post #217188 8th Mar 2013 6:01pm
From another vehicle? They will never reach Mr. Green
Post #217190 8th Mar 2013 6:03pm
pope10001
Rolling with laughter Rolling with laughter Rolling with laughter
Post #217191 8th Mar 2013 6:04pm
borderterrier
Regards,
Mark
I had an old 200tdi Defender and I put them on from a Peugeot 405, they looked and performed superb
Post #217192 8th Mar 2013 6:16pm
pope10001
Any pictures at all Steve?
Regards,
Mark
Post #217193 8th Mar 2013 6:26pm
borderterrier
Regards,
Mark
That 200 tdi was a while ago, but I shall have a look for you
Post #217194 8th Mar 2013 6:28pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I guess you could get the washers off a Disco. They are also heated. If its possible to get the pump as well then it might work.
Otherwise, as stated above, the water will never reach the screen....the phrase " Censored ing in the wind" comes to mind... Laughing
Simon
Post #217196 8th Mar 2013 6:36pm
GUM97
Mate of mines got some on his, off an old Ford Escort Laughing They don't seem to be affected by the wind either strangely enough Thumbs Up An engine to TDi for!
Post #217205 8th Mar 2013 6:55pm
hi Mark
I was looking into the same thing a couple of months ago. Looks like you have a tdci now, that makes a difference, The tdci bonnets have a lump wher eyou can hide/angle the washers.
I was planning on using heater washer jets from a 3 series BMW, together with the automatic temperature switch. You can buy the loom from BMW for about £90.00. Since going on the trip I've not had time to look at it again.
if you google it, there's a guy who has done a step by step heated jets fitting. As above, other options are to fit Peugeot style washers onto the wipers themselves or fit 2 sets of defender jets into the grommets next to the wipers.
For me, MOT next on the ICE
Post #217213 8th Mar 2013 7:09pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
I think the Peugot up grade is a very usefull one I did it on a disco 200 tdi may well do it on my 90 as well use the opseing wiper box holes and a t pice
Post #217217 8th Mar 2013 7:26pm
borderterrier
That's what I did on my tdi
Post #217271 8th Mar 2013 9:36pm
