![]() | Home > Maintenance & Modifications > RDX Lights |
| Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487
Evening Guys and Girls
Well I've just fitted the first part of my lights and I'm bloomin frozen. Looks really good though and great value for money, I'll finish the indicators tomorrow and fit the side power vent. Now time to break open the Thatchers and start the chicken casserole. Any advice on sound deadening and insulation? Is there anyway to warm the cabin up quicker in the Old Girl? I'm in and out of 2.2s all day long and they definitely warm up quicker. Cheers Guys |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
There are alternatives, but a search for 'Dynamat' will tell you all you need to know. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Dynamat for insulation and soundproofing
Group buy here http://defender2.net/forum/topic17772.html Simple check to make on the heater that can make a lot of difference. Set the hot/cold lever to full heat. Open the bonnet and check the arm on the heater box that the cable is attached to. It should be FULLY over to the right when looking from the front. See if you can move the lever any further to the right by hand. If you can then adjust the cable so the lever is fully over. You may only get a few extra mm's of adjustment but it really makes a difference. I had to wait ages for the TD5's heater to give warmth into the cabin. I did this check and had about another 3mm of travel on the lever. Adjusted the cable and now the heater blows warm in about 5 minutes and hot in about 10. If you have the dash top off also make sure all the hoses are connected fully, they have a habit of working lose over the years. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Dynamat is not an insulation though so your best to dynamat and then stick closed cell foam over the top.
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1458
Agreed, but as a added bonus it dose aid retaining the warmth. One of the benefits of the aluminium face. Mine is noticeably warmer I put closed cell on the sides, any where above the floor is good but having read others experiences, decided against anywhere that would get wet !! |
It doesn't matter if closed cell foam gets wet as it doesn't retain water.
sorry I meant open cell
Brilliant, thanks for your help guys, I'm off tomorrow Bob so I'll try your method on the cable. I thought that Dynamat was the way to go so a bit on saving to do then that could be the next job. Where's the best place to get seat risers from?
Cheers Life is one big adventure, that's why we have the vehicle for the journey. |
Probably Mud Rails direct from Mud unless Leeds (Brandan) does them, drop him a PM.
The Exmoor ones are expensive and a pain in the proverbial Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Yes we have the Mud seat rails in stock
Brendan |
| All times are GMT |
