![]() | Home > Puma (Tdci) > creaking |
| adiep Member Since: 18 Nov 2012 Location: Gibraltar Posts: 204
Hi guys, what might cause creeking/squeeking when i go round a corner or over potholes, think its from rear. - like a giant budgie.. any ideas?
| AndyS Member Since: 18 Aug 2012 Location: London Posts: 597
My one suffers from panel rattle internally, an annoying squeak that goes off for no apparent reason. To fix it I had the wife ride in the back listening for any noise and then packed it out with cloth until it stopped. At the moment the only rattle I have is the passenger side slide window and only when it's cold. I figured as it's spring (almost) I don't need to worry about that for a while.
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677
Something in my dash does it over large bumps, think its near the clock
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Panel rattle + I've got a bee in my bonnet at around 2200 rpm - metallic high-pitched buzzing in the engine bay in all gears.
Currently trying to convince myself it's all in my head... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Damn - it's real then
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Turn the wireless up. 2005 Td5 90 XS
Steve |
Radio or not, I know its there!
| nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720
Well if it helps I had a similar problem as you described. I have a 110 SW. My noise came from the middle seats. I traced it to the seat mechanism for lowering/folding the seats. I greased and sprayed, hey presto' noise gone. Good luck. |
110 here also... trying that ! |
I've trained myself to do that In my case, as it's persisted for 2 weeks and the vehicle still moves, I'm not all that worried for now But shout it at them in German because life is also terrifying and confusing... |
| All times are GMT |
