![]() | Home > Puma (Tdci) > Check your nipples |
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 ![]() ![]() ![]() |
Same as mine, went to grease up the propshafts at 3k and found the front prop UJ adjacent the transfer box had the grease nipple missing.
Checked the others and they were loose as well. It got replaced when the fuel pump died the week after and had to be recovered to the dealers Tony |
dshickle Member Since: 09 Oct 2007 Location: Epsom Posts: 36 ![]() ![]() |
where are the grease nipples. Have had a quick look and can;t spot them.
And is there any specific grease type that needed. Any help greatly appreciated. David Disovery 3 TDV6 SE Defender 90 XS 2.4 Defender 110 S D250 (MY22) |
The grease nipples are in the centre cross of the UJ, not like my other 90s wher they are in the side of the UJ and easily seen. I could only detect the hole by feel and even knowing where it is its difficult to see. The grease nipples are cranked at 45 degrees and difficult to get a grease gun onto. They may need rotating slightly.
Tony |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Dont joke my 90 is missing the passenger side dash inspection panel - i dont want to look to see if anything else is missing
I re-checked my MY2010 defender 110 and the front prop still only has 2 nipples, at either end, should I have a middle nipple ? can the be a sorted out on the warranty ?
the dealer will fit new props to any Def that has missing nipples, it was a manufacturing fault they weren't tightened up 2.4 90 XS
cheers grockle
![]() 1968 1/32 scale Britains 109 Pick up. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
Off road vehicle without nipples? Cheap solution IMHO Puma 110" SW
