Home > Maintenance & Modifications > Battery Trickle Charge
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
I want to know whether I can trickle charge my battery this weekend without disconnecting the leads or venting the battery (not sure if there is a vent)? Reason being I have aftermarket seats fitted that I have to unbolt to get to the battery, when I put these in I also fitted some remote battery points on the outside of the seat box in the passenger foot well. I did this mainly becuase if I ever got a flat battery I could attach jump leads quickly.
Thanks chaps:?:
Post #21553 8th Jan 2010 9:35am
K9F
Trickle Charging.
I can't see any logical reason why you can't do as you propose. Obviously if the charger is adjustable by lowering the charge amperage and increasing the time period this will 'err' on the side of caution. My motorcycle languishes in the garage all Winter with the alarm set, this in turn will flatten the battery in about two weeks. Solution: Trickle charge it on a permanent basis on an 'Optimate' the only thing one has to do is periodically check the electrolyte levels. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21554 8th Jan 2010 9:45am
DAZ110
mrwoo,
Halfords do a maintenance charger that you can connect to the battery with a plug connection that you connect to outside the battery box. About £23.99 I think? Product number: 188946
Why can't you connect a charger to the remote battery connection points you installed?
Post #21559 8th Jan 2010 10:30am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Which engine does you defender have? when the battery went dead on the puma, we charged it while it was still connected to the car electrics. result - Censored ecu. 110 Tdci Double Cab
Post #21596 8th Jan 2010 3:27pm
Cibit
I got this months Caravan club mag and it had a cataluoge (sic) with it and a cool power pack that starts your car via the cigarette lighter and once car is started you can recharge power pack via the cigarette lighter. It also has an option to charge from the mains.
Aha found a link, whether it has the oomf to start a dead defender is another matter but it may be useful to you Thumbs Up
http://www.easylifegroup.com/products/2815.asp
Sorry about spelling I have brain freeze Rolling with laughter 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #21599 8th Jan 2010 3:44pm
mrwoo
My battery is not dead, I just want to trickle charge it this weekend to maintain it. Apparently this is something you should do every few months or so as a vehicles charge will not kill of a build up of unwanted electrolytes?
Post #21612 8th Jan 2010 5:44pm
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
Buy a CTek 3600. Connect the fixed cable set and connect whenever you need. I have two sets. I use one car and the other two are connected to the Ctek. battery stays full charged without problems. Thumbs Up
Post #21881 11th Jan 2010 8:06pm
mse
First off the genuine LR batter is vented - ignoring the battery box in ALL defenders is not air tight and vented its self!
Second - you do have to be careful jump statring cars with modern ECU's - although i know of many who ignore this and are fine - trickle charging (not jump starting) i would think shouldnt be a problem Mike
Post #21883 11th Jan 2010 8:13pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Folks - apols for resurrecting an old thread but I too have a Ctek charger and was considering the idea of leaving the fixed charging cable set in place for easy trickle charging/conditioning from time to time.
Last year, there seemed to be a mixed view with regard to the implications on the ECU of charging the battery whilst still connected...maybe perhaps more so for the Puma (mines a Td5).
Just wondered if anyone has any more recent experience of this or new views ?
Cheers, Jon - 110 td5 [sold]. Currently Defenderless.
Post #64224 18th Mar 2011 12:33pm
BigMike
Not sure of the logic of doing this with a perfectly serviceable battery.
and re jump starting - always put the earth to the chassis/good bit of steel on the car being jumped, dont put the earth cable on their earth terminal, its v bad news.
Post #64225 18th Mar 2011 12:36pm
Any charging method that it as smooth as the alternator output (rectified three phase) and does not exceed the peak alternator voltage should do no harm to anything else connected to the battery at the time, so trickle-charging with a good quality charger (such as CTek) should be fine. (Some chargers use a half wave recitifier for a c.12V rms output, which actually requires a very much higher peak voltage).
Chargers like the CTek are designed for long term regulated use and avoid many of the problems with electrolyte boil-off that cruder chargers can cause.
It is advisable to ensure that there is good ventilation around any vehicle battery whilst it is being charged, although it is generally no longer necessary to loosen the filler plugs on top! I have seen a large battery on a wheeled loader explode (I was standing the other side of the machine at the time) and it is not nice at all, fortunately on this occasion no-one was hurt but the battery acid covered everything within 30 yards.
I would be very wary about using some of the very high output (start/charge type) chargers on a modern vehicle due to the the risk of component damage.
Post #64227 18th Mar 2011 12:56pm
Naks
I have a CTek and have charged the Audi and my previous Disco2 with the battery in the vehicle.
IIRC, the most important thing is to remember to connect the charger negative terminal to the body of the vehicle and not to the battery's negative terminal!
And you are right, you should do this every few months or so, since the alternator cannot fully recharge an auxiliary battery. --
Post #64260 18th Mar 2011 2:59pm
The reason for making the final connection (whether with a charger or jump leads) to a location remote from the battert is to reduce the risk of explosion if the battery is giving off hydrogen, which it may well be if charging. With a charger it is not so important since the charger should be off at the mains when connected, so the risk of a spark is small.
Post #64327 19th Mar 2011 9:16am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi,
I have a cteck 3600 permanently fitted next to my battery with a camping plug set wired to the bulk head. Been plugged in now for 2 weeks.
We use this as an electrical hook up at camp sites and also for charging at home if left unused. No problems at all with just a wire going under the bonnet while on charge.
So we have 240v sockets and the battery is looked after by the charger while the fridge/lights are on.
Post #64337 19th Mar 2011 10:51am
mse
Do you know, that could be one of the most simple and neatest ideas ive seen for a long time! Mike
Post #64339 19th Mar 2011 11:28am
