![]() | Home > Technical > How to fit xs side step/bars instructions? |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
The steering guard uses M10 or M12.... If you can wait, I can bring my rivnut gun to the rolling road day, is only 2 mins to fit a pair of rivnuts... Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
| Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320
Hi Ian, That would be great mate if you could help Stu |
| LinDens90XS Member Since: 25 Feb 2012 Location: Merseyside Posts: 83
If I may make a suggestion, take off the bungs on the ends of the main tube and wax oil inside and every time you power wash take the bung off again to drain as water makes its way inside through where the checker plate is riveted. Just replacing mine next week as mine rusted through from inside. Hope that helps.
Regards Dennis. |
Regards Dennis. |
Just removed rusty steps and my apologies, water not entering where checker plate riveted but at the top of the tubes where fixed, they are open so power wash and dunking in muddy water just filled it up and nowhere to go but rust.
Regards Dennis. |
| Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878
Going to revive this thread in the hope that someone would be kind enough to measure their support bars so that I can make some
Cheers |
| ROB1N Member Since: 27 Jan 2013 Location: South Wales Posts: 22
Hi i have a set of these bars but no instructions does anybody have some or at least a pic of what they attach too cheers Rob. |
| Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86
It’s quite obvious when you offer them up under the truck Robin. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma |
i did but there appears to be something that is missing ?? just a photo of where they mount before i amke some mods
They look complete in the pictures.
The front bolts along the inner sill, the stay bar to the chassis and then the rear bolts in to two existing bolts and finally there is another bolt hole just below that. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
Sorted had to make some support bars and sort out some fixings etc
