Home > Puma (Tdci) > exact process for changing the fuel filter ?
rossy
I've done a search and there's lots of stuff about the filter like fill it with diesel and the threads are the opposite way round etc but I'm not confident to do it just yet. The sort of thing I'm a bit mystified about is - do you need to remove the road wheel ? How does the filter shroud come off ? Does it come off clockwise and is it lugs or threads?
Please advise as if you were showing a moderately trained chimp ! Laughing
Thank you
Post #215309 1st Mar 2013 6:54pm
Dieselhead
I have always done it like this.
Get a good brand of filter. Not britpart as I had a mates puma die up the road caused buy a faulty filter sucking air.
You dont need to remove the wheel
Remove the metal cover from arround the filter
Fill up the new filter with clean diesel
Place a catch pan etc under the area where your working
Twist the old filter anti clock wise until it stops. Then pull it down.
Theres luggs. 3 if I remember. The largest towards you. You cant go wrong
Push the new filter up into the housing & turn clock wise until it stops
Start the engine & let it run. Best to have over half tank of fuel
Refit the housing over the filter
Job done.
Its always worked for me Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #215342 1st Mar 2013 8:32pm
rossy
Thanks dieselhead. Does the cover just pull off ? (can't see any screws)
Post #215381 1st Mar 2013 9:49pm
spudfan
Ireland
There is a plastic nut on the cover on the rear wheel side of the cover. Loosen this-it will stay attached-then ease the cover off. It will have two retaining lugs on the side nearest the front wheel but will ease off o.k. Refit by siting the lugs in place then turn the plastic butterfly nut once it is correctly sited in it's retaining hole. It's a little fiddly but o.k.
Had to edit the origional post as I had everything arse about face,i.e. wrong way around. Whistle Hav'nt drained the filter recently! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #215383 1st Mar 2013 9:59pm
rossy
Thank you Spud. I drained mine the other day (havent changed it from new) and only a couple of drops of water came out followed by a load of diesel which went down my arm and ruined my jumper. I put it in the wash and the missus chucked it straight outside as the whole utility room smelled like a garage forecourt ! Laughing
Post #215481 2nd Mar 2013 9:40am
BigMike
When you screw it back on, it's not "seated" until you feel a definite click. It helps if you clean the new filter so it's not greasy and you can grip it properly. Try not to spill fuel down the side of it as you wont be able to grip it to turn it- it doesn't matter if its not full to the brim.
Post #215489 2nd Mar 2013 10:12am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
And try not to get any on your jumper either rossy. Laughing
Post #215491 2nd Mar 2013 10:24am
spudfan
Ireland
When I put up the origional reply and had second thoughts, I did the sensible thing. I sent the wife out with a flashlamp to check. Just as well as she confirmed that I was incorrect Mr. Green 1982 88" 2.25 diesel
Post #215507 2nd Mar 2013 11:27am
Glynparry25
Couple of other little hints:
Clean the filter area before working on it. If you get some dirt in the new filter as you are fitting it you will have it sucked up to the pump/ injectors.
If you have a bleed tool, fit the new filter dry and then draw the fuel through- that way you reduce the chances of contamination even more.
Finally, Good luck Thumbs Up
Glyn Dog Sheep
Post #215552 2nd Mar 2013 5:05pm
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
be useful if there was a PUMA "howto" section where these "howto's" could be recorded.
Post #215620 2nd Mar 2013 9:22pm
rossy
Again thanks everyone for the tips. I've no excuses now have I ? Very Happy
Post #215863 3rd Mar 2013 7:42pm
spudfan
Ireland
Are we there yet? Rolling with laughter 1982 88" 2.25 diesel
Post #215897 3rd Mar 2013 8:51pm
rossy
right I've just done it. Messier than I thought. I wasn't prepared for the torrent of diesel that pishes out of the housing so another jumper ruined ! And the drive.
When I put the new filter in I didn't see any lugs so I just twisted it around gently until I felt it go up into the housing. Then I screwed it until I heard a faint plasticky clonk. Hopefully that means its seated properly. I noticed however that it was fairly easy to undo it if I twisted the filter anti clockwise so who knows.
The engine started fine so I left it idling for a few minutes and I didn't see any leaks around the housing. Does that mean its been done properly or if it isn't will I get air being sucked into the injectors ? Fingers crossed.
Post #219272 15th Mar 2013 3:40pm
spudfan
Ireland
Another notch on the bedpost on the road to manhood. Mr. Green Congratulations Thumbs Up 1982 88" 2.25 diesel
Post #219311 15th Mar 2013 6:20pm
Was looking at this the other day, even with the quarter turn fastener tight the whole shield rattled.
Post #230324 24th Apr 2013 11:16pm
