Home > Puma (Tdci) > Weird Temperature issue
Page 2 of 3 <123>
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
off topic
how was morrocco matt? where are your photo's you've been on here a few minutes and none!!!! Whistle
Post #21478 7th Jan 2010 1:10pm
mse
To be honest i dont really have any problems with the patch - i may even have the latest it was only done around Nov.
Thanks guys
So it would seem its perfectly normal...and if i want to stand out in the cold either go in the disco or dont bother leaving the engine running - where is the temperature sender on the puma? Mike
Post #21479 7th Jan 2010 1:13pm
merebrowpaul
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
same same
i have an 09 and that does it aswell no other probs tough touch wood Thumbs Up
Post #21506 7th Jan 2010 9:28pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Parked up at the station this morning and, given the train was running late, thought I'd do a (semi) controlled experiment for you.
Turned lights off but left the engine on and heating on setting 1 (high heat). It must have been around -4 outside.
Within 5 mins it had dropped to 1/4 way up the gauge. I reckon it would have been cool in another couple of mins. A quick check under the hood and the viscous fan was busily whirring away cooling the engine! One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #21517 7th Jan 2010 9:42pm
merebrowpaul
So is this a fault or not.?
Post #21520 7th Jan 2010 9:51pm
peanutbob
No fault. If, at -5 deg c or similar it was running at normal mid temp at tickover, then in the summer it would overheat towing a trailer up a hill, or general driving in a hot country. Doing away with the viscous fan and substituting it with an electric fan will make a difference, in the winter at least, but whether it can adequately cool the defender in 30 deg+ C temps, I'm not sure! Otherwise why do LR keep fitting a viscous fan? On my TD 5 I created a rad muff with a rectangular rubber house door mat which fitted perfectly using a metal coathanger to lock it into to place in 2 holes under the bonnet and used this all last winter to good effect, and then put the door mat back at home after hosing it off.
Post #21526 7th Jan 2010 10:25pm
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mine does this too.
Post #21527 7th Jan 2010 10:29pm
Petrovich
Russia
Its normal for diesel Defenders. Defender 110 '07
Post #21529 7th Jan 2010 10:49pm
peanutbob
Quite so. What I was wondering was at what minimum temperature does diesel nowadays start to clog? The additives put in nowadays results in much lower temperatures can be achieved before this occurs, but what is the min temp? i seem to recall a while ago supermarket diesel was the best for lower temps, but maybe it's uniform now. We used to have to put additives in the truck diesel over 10 yrs ago, but not now.
Post #21531 7th Jan 2010 11:13pm
YORKSHIRELAD
Both my old Td5 and my tdci loose temp when stationary in the cold. It's got a lot of air space at the front I guess?. 1963 Series 2A truck cab
2008 110 SW
Post #21532 7th Jan 2010 11:17pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Aha! Glad I found this! Mine is doing the exact same thing too! Glad to know I'm not the only one. Phew!
Post #21533 7th Jan 2010 11:23pm
peanutbob
In extreme low temps, like -20 c, I'd prefer to get my diesel from well populated garages to avoid the risk of separation, and also leave the handbrake off but in gear to avoid it freezing on if driven thru snow/slush during the day. Same applies to EPBs.
Post #21536 7th Jan 2010 11:38pm
alantd
Mine doesn't work very well when I pull it on so no danger of it freezing up Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #21538 7th Jan 2010 11:40pm
peanutbob
5 notches then..?
Post #21540 7th Jan 2010 11:43pm
Glynparry25
Mine has been doing the same- when not on load the temp drops- but this is only expected on an efficient engine. But today after a play in the snow it didn't do it any more. Looks like a thick coating of snow across the whole grill was blocking airflow. From this I will probably be buying a grill muff for these cold days Smile.
Glyn
Post #21543 8th Jan 2010 1:16am
Page 2 of 3 <123>
