Home > Technical > Help!! Wiper rack too long!!!
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Just withdrawn the front wiper drive cable from the front of the car and the new 'Britpart' cable is about 50cm longer than the old one. Old one is mucky but complete. Is the new one meant to be cut to length? 03 County HT Def.
Post #214982 28th Feb 2013 11:43am
chipmunk
Panic over, supplier says you cut to desired length.
Post #214984 28th Feb 2013 11:49am
Typical Britpart.
Wonder what else you'll find wrong with it......
Post #214986 28th Feb 2013 11:56am
chipmunk
Yes I know! Got the whole dash out.............original reason intermittent wiper seizure so going the whole hog and doing dual washer jets and side vent window demister. Looks like a road crash in the cab. At least the weather is great but cool and sunny. If Britpart did weather.........!! Very Happy Sad
Post #214990 28th Feb 2013 12:05pm
chipmunk
Jim you must have known what I was about to go through?! Old cable out, tried to thread new S...part one in..............no go. Spiral cable in no way matched the teeth in the wiper gearboxes. Cleaned old cable thoroughly with brake cleaner (it was fine) along with cable ducts, gearboxes etc and put old cable back in........works fine and quietly. Can't remember having that much trouble with BP bits in the past but have I just experienced what others complain about!!!!!
Just the washer tubing to connect and sort the side vent ducting. And reassemble of course!
Post #215039 28th Feb 2013 4:24pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Not tried a Britpart one, mainly because the genuine ones are one of those items that are so cheap it's not worth buying after market. Renewed rack and both wiper boxes in Pam's 90 not long ago - I feel your pain !
When you put the dash back together don't catch the washer pipe between the plastic "filler" section and the bulkhead... I had the whole dash back together before I found out I'd done that... http://www.yorkshireoffroadclub.net/
Post #215063 28th Feb 2013 6:17pm
chipmunk
Thanks Dave, I'm doing so much while it's in bits that I'm being twice as OCD as I am usually. Funnily enough I had been looking at the tube routing until a bad migraine stopped the progress for the day. Very annoyed as the weather was playing game for once. Will also test and re-test before reassembly. Cheers.
Post #215095 28th Feb 2013 8:02pm
