![]() | Home > Maintenance & Modifications > Dynamat |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Doing the doors makes a great difference
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
oooh ok. Might need to add them to my list as well. Might need to get some more! I bought 80sqft for £280 on ebay. I have used a bit over half of it so far.
And the roof...
Thanks SGH. Looks like a top job you have done there.
Got back ache at the weekend trying to roll all the Dynamat on the roof as it needed quite a bit of heating and rolling considering it was so cold. |
Finished my 130 at the weekend
![]() Chadjizz and I plan to see difference between mine and his 130 that has not had any Dynamat. Downloaded DB meter app on my iphone ![]() |
I was amazed at the difference today. I have to admit when I first saw the Dynamat I thought that a bit of rubber and some aluminium could make much difference but I was really impressed today.
Wish I had thought about doing this when I was rebuilding it and then I would have done the bulkhead and everything as it was built up to make it so much easier. |
Tarrel Member Since: 21 Sep 2012 Location: Ross-shire, Scotland Posts: 94 ![]() ![]() ![]() |
I've just started on the Utility Wagon, using SilentCoat instead of Dynamat. I understand it goes on much easier. Certainly had no trouble cutting, bending and sticking it, and temperature was minus 2. Just put the pack of Silentcoat on top of the Rayburn for half an hour, and ran the engine to warm up the interior.
Just done the floor, arches and side panels in the back so far, but it's made a big difference. Thanks for the advice about the doors. Will start saving for another pack or three! 2012 Defender Utility Wagon 1981 SIII 88 inch SW Follow our blog: www.newlifeinnorthernscotland.blogspot.co.uk |
Just looked up Silentcoat and it looks like an exact copy of Dynamat but only £80 for 40sqft as opposed to £140 for Dynamat that I paid.
Looks like I will get that if I use up all my Dynamat and still need more! |
Yep, I think it's the same basic idea; a butyl-based heavy mass layer with an aluminium facing and adhesive backing. I believe you can also use Butyl-based roof flashing tape, but when I looked this up at Screwfix it worked out more expensive than the Silentcoat!
![]() 1981 SIII 88 inch SW Follow our blog: www.newlifeinnorthernscotland.blogspot.co.uk |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 ![]() |
out of interest, any views on if this will help with condensation?
Not on its own but if you stick closed cell foam on top it should.
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
A massive difference since doing mine, but decided at the weekend to once and for all strip the roof lining off my 110 to Dynamat it as there was still a rattling noise.
Thank god I did, all the bolts/nuts holding the roof to the sides were loose ![]() I know it's a Landrover, but not one bolt was tight and it's only 2 1/2 yrs old. Got me worried now whether a strip down should be planned ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Just keep driving it.... with nuts & bolts like that, it'll soon strip itself! ![]() |
You have a point there ![]() ![]() |
