![]() | Home > Technical > Hazard light switch - illuminated or not? |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
That is correct, yes. Only the two green arrows for the turn signal will flash. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314
Cheers Ericvv
Superspoons |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Well, changed the Hazard switch bulb today so now I have an illuminated switch. Took 10 minutes in total.
Ericvv, you stated that when the Hazards are on you get the 2 green indicator arrows. I get that + a red warning triangle on the dash. Do you get that also?
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Correct, same here. The only thing that does not happen is the red light in the distress command button flashing when in the on position. Which is different than most other cars.... But that is what makes it a Defender,yes? http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 889
Mine works exactly as it should:
Switch only illuminates with lights on; when activated both indicator warning lamps flash in the display panel, along with the triangular hazard warning lamp in the display panel - the switch itself stays constantly lit. AND the trailer direction indicator warning lamp flashes, which it doesn’t do if a trailer bulb has blown. Peter |
| PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511
For anyone who needs an STC1205 bulb and holder for their hazard warning lights switch, you may be interested in this eBay listing -
BRAND NEW RANGE ROVER P38 HAZARD WARNING LIGHT SWITCH - AMR2691 - LAND ROVER
These switches are £1.00 each + £0.71 postage (to the UK) Each switch has 2 x STC1205 bulbs in it If you buy an STC1205 bulb and holder from a dealer, they're £3.40 each (incl. VAT) . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 3rd Dec 2013 11:55am. Edited 1 time in total |
Too true, Paul. Just received my switch £1.71 in total. Bulbs added to my spares collection. Told my local Indy - he is ordering some.
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270
bulb is in red housing in bottom of switch -
Click image to enlarge |
Mr James, were you able to take that switch out of the dash without removing the dash, so without accessing it via the rear? How does that work? I believe my dealer had to release the center dash to get to the back of the switch when replacing the bulb.
Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
You do not have to remove the dash, just the radio so that you can put your hand in and up behind the switch and push and wiggle it forward. You do not even have to disconnect the radio to get access. Takes less than 5 minutes if you have the correct tool to remove the radio. I have a 3rd party radio with its own fixing cage and I was still able to do it without removing the cage. If you still have an original LR radio then it is even easier as there is no fixing cage, well there wasn't on my 2010 MY XS.
Very easy. I removed the radio with some cheap release keys off ebay that cost £1.99; (left it connected) then pushed the switch out from the rear. easy peasy.
| All times are GMT |
