![]() | Home > Maintenance & Modifications > Second 12V socket |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
Hi all
I need to install a second 12V socket in my Puma, I already have the socket but don't know where can I take the wires to make the connection, Is there a properly location in fuse box (for auxiliary electrics for example????)?????????? It need fuse or relay??????? thanks!! |
Where do you want to mount the socket ?
Don't know the location yet, but I'm thinkig under drivers panel, near of fuse box and pedals (remeber that is a left hand one).
But I don't worry about the location, I worry about the wire conections, I don't know from where to take the energy, and don't cause any overcharge in eletricals, understand?? |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Gabriel,
Just from memory... As far as I remember there is a set of cables to connect an auxiliary 12V outlet in the back, near were suppose to be the rigth side speaker. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge Last edited by Eduardo on 5th Jan 2010 7:16pm. Edited 1 time in total |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
That's correct Eduardo, had mine fitted there, dealer did a thouroughly neat job.
Pictures of the location of the cables?????
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Correct,, and fed from the aux fuse under the righthand seat box !! Their is meant to be another take off, in this feed, approx half way down the vehicle,, but have never found it ![]() ![]() Main Brian James Trailer Dealer for South West UK |
If someone knows the position of this second outlet please advice!!
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
If you do a search you will find the one at the back
Just a point - that pack of wires doesnt run down the car so it would likely be outside on the chassis leg if there is such a feed or under the drivers seat Mike |
MSE
Pillar would be a good option to search, I didnt found nothing in the passenger seat (in our case) Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
There is nothing behind the trim under the windows (remember mines a 90) Mike
