Home > For Sale & Wanted > K9f guide to Safari Equip single pivot wheel carrier.
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I have for sale a Safari Equip wheel carrier. Its the one that attaches only to the crossmember (and door) as shown in the picture below (not my picture BTW) I haven't taken a picture of the actual one as its currently in the loft, but this pic shows exactly how it looks when fitted.
This is a heavy duty bit of kit, in excellent condition being only fitted for a short period. It is compatible with SE bumperettes which are available from Brendan (as shown in the picture).
Comes with fitting kit as supplied including the anti crush tubes for the crossmember.
The carrier can be adjusted to give two different wheel heights, the higher one ideal if using a tow bar.
There is quite a bit of info on this carrier on here.
Price new as far as I know is around �425, SOLD and collected. I think its a bit heavy to arrange postage.
I'm at Wimborne, Dorset.
I can take paypal, card or bank transfer whichever is easiest.
Thanks
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #208497 5th Feb 2013 10:58am
K9F
PM sent..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #208518 5th Feb 2013 1:10pm
d j hutton
Replied to PM's.
Buy British 🇬🇧
Post #208521 5th Feb 2013 1:37pm
d j hutton
SOLD
Sold and collected.
Thanks for the interest.
Buy British 🇬🇧
Post #208532 5th Feb 2013 3:15pm
K9F
Thanks D J.... Thumbs Up Will let you know how I get on with fitting. Nice to have met you! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #208549 5th Feb 2013 5:25pm
d j hutton
Thanks for that, nice to put a face to a name.
Fitting should be a breeze Thumbs Up
Buy British 🇬🇧
Post #208551 5th Feb 2013 5:29pm
Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Post #208652 5th Feb 2013 8:35pm
K9F
Managed to do a little preparation for the fitment of my purchase.....
Went to Eurofasteners and purchased a complete set of replacement stainless steel fixings. Ran them via a drill and some Autosolvol to polish them up a bit.
Excuse photo quality but low light and a Cwapberry to blame....
DJ was kind enough to supply me a roll of high density foam to use as gasket for the door plate etc....provisionally cut gaskets. Holes still to do but marked with marker pen.
The carrier came ready-assembled so broke it down for ease of fitment to rear crossmember.
Will 'revisit' it either Friday (if I can 'swing' no pun intended a day off) or the weekend, weather dependant....Thanks again DJ. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #209047 6th Feb 2013 9:22pm
K9F
Forum trawling....ain't it great? Thumbs Up
Did a trawl and found this pertaining the wheel carrier.....
BigRuss wrote:
Oh and one final thing, you need to ask for some extra crush cans to fit in the cross member, if you have enought for every bolt that goes through would be good.
Potentially I have 8 bolts and only 5 anti-crush spacers...... Whistle
Got a new set 'knocked up' out of stainless today at work (original one is the one in the middle)..... Thumbs Up
Post #209287 7th Feb 2013 8:05pm
K9F
Got the rear bracket fitted today. Only needed 6 anti-crush spacers after all as the two end mounting holes (the two depicted without bolts fitted) have anti-crush tubes fitted/welded as standard in my 90s rear crossmember. Also these two end bolts are 20mm longer than the rest so the ones I sourced weren't long enough. All bolts were heatshrunk and anti-crush spacers filled and coated with Waxoyl (once I had sat the tin on the woodburner to get it runny). Both front and rear plates have had gaskets made from high density foam. Pivot arm has been dismantled and treated to waxoyl on the inside, bearing housing cleaned out and regreased. As tempting as it was to fit the arm, shall leave it until I get the extra length bolts required.
With a little 'rework' on my bumperette I shall with 'revised' mounting brackets pick up the mounting holes of the rear swing away plate and be able to retain it.
All work in progress but enjoyable all the same...... Thumbs Up
Bumperette rework....
Post #209851 9th Feb 2013 5:01pm
d j hutton
So that's what those longer bolts were for! Brendan take note Thumbs Up
If you can do a write up and publish as a PDF you'll be revered all over the land, Bow down
It's looking good.
Wales is looking damp Whistle
Dj 1989 200tdi 90 csw
Buy British 🇬🇧
Post #209893 9th Feb 2013 7:09pm
K9F
Got bracket finished off today. Used Transit wheel nut covers filled with Sikaflex to protect and seal the bolt heads and nuts under the rear of the crossmember. Didn't bother with end bolts as the bumperette is having new brackets manufactured to pick up these bolts and I should be refitting it next weekend hopefully.
Rear door panel fitted with high density foam gasket, adjusted and waxoyled and carrier head fitted. Had to shorten the wheel mounting studs to take the stainless Wrington wheelnuts. Fitted high density foam gasket to the head along with PTFE washers with stainless washers inside to protect the wheel as I did on the original door carrier.
In summation a very well engineered piece of kit. Took some 'fettling' to get it fitted and how I wanted. Decided to mount the wheel on the higher mounting position as with tinted windows I couldn't see bu993r all out the rear anyway. End result.....
Post #211695 16th Feb 2013 5:10pm
nice job Mal, given the weight of the wheel carrier and those HUGE wheels, you may need to adjust your headlights!
Post #212203 18th Feb 2013 7:48pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
As always Mal, great job...looks a really sturdy carrier that Cool
great Wright up as well Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #212710 20th Feb 2013 7:12pm
K9F
Thanks Karlos....Went to Kimmeridge and nearly took Ruby's block off due to the slope/wind and weight of rear door self-closing. DJ came along with an attractive offer and I jumped at it.
Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #212714 20th Feb 2013 7:15pm
