![]() | Home > Maintenance & Modifications > rear passenger door cards help reqd |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
when i was installing a pair of door stay extenders i gently prised off the door cards to be able to install a couple of bump stops and it appears that i have sh@gged up the door trim clips.
i did not remove the whole door card but the trim clips look as though they were bonded onto the door card; were being the operative word. has anyone got experience of these fixings (fcx Matt?) and best solution to my problem. Farmer Giles top tip - don't do maintenance or modifications on your Land Rover when you are in a very bad mood ![]() |
Bond the bit you've ripped off back on again with Gripfill or similar
cheers Matt
![]() i was tempted to drill through the door card so i had an easily assessible trim clip like the older door cards |
![]() They are Land Rovers; they are supposed to have visable fixings ![]() |
Hot glue gun is better & quicker but not the cheapy ones
just out of interest is there a special tool for removing the door cards so that the clips don't need rebonding; or is it just a slow and steady careful pry off with a screwdriver?
There are trim pad removal tools available but they don't guarantee success - it really is a case of taking it slow.
http://www.google.co.uk/search?q=trim+pad+...p;ie=UTF-8 Ken's way is also fine, I meant some form of adhesive, not necessarily Gripfill |
thanks Ken and Matt
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
Black silicone and gaffer tape, easy to remove every 6 months to repair the central locking cables.....
cheers keith,
it looks like i'm not the only person to break trim clips then ![]() didn't realise it was you when i pulled out in winchcombe last week; your Land Rover certainly looks well planted in the rear view mirror! ![]() |
The clips break more easily in cold temperatures, so get the vehicle in a warm place if you can. Steve.
cheers MOG,
with my workload it may well be summer before i get round to fixing them ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Press the door card by the winder handle towards the outside of the vehicle and you will nearly see a spring clip round the shaft of the winder handle.
Carefull pop the spring clip off with a suitable pointy thing and the andle will come off. Alternatively a rag passed round the winder shaft can be used to pop the clip off. Once you've seen how it's fixed, it isn't difficult to take them off. |
