Home > Puma (Tdci) > Battery wire size
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
Battery wire size
Can someone please tell me what gauge of wire is used for the negative feed on a TDCi. I would like to change the connector on the negative terminal as it has the silliest of connections on there that means I cannot add another cable onto the terminal. I am not at home at the moment or I would just go out and measure it but i would like to get the materials ordered so it is sitting waiting for me to install when I get home.
Looking at the connection it looks like i will just have to chop the old one off and put on a crimp with an 8mm hole for the new terminal I shall fit, that is unless somebody has a better idea.
Thanks 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #212214 18th Feb 2013 8:18pm
ethanicus
2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I also had this issue when I wanted to add a Blue Sea Aux fuse box. I didn’t want to cut the terminal, but if you did I believe a 35mm2 terminal is required.
In the end I removed the current T style bolt and replaced with a longer ss bolt (m6 from memory). I simply ground down the head to match the existing bolt. Refitted as normal then used a spring washer and nut to secure a M6\16mm2 terminal as per below.
Hope that helps?
Post #212245 18th Feb 2013 9:58pm
jst
35mm is std i believe Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #212247 18th Feb 2013 10:03pm
jayaway44
Thanks guys, is the 35mm you are quoting the terminal size or the cable size, is the cable 25mm, 35mm or 40-50mm. Thanks for the picture I can't quite imagine it at the moment and will need to look at the battery when I get home.
Thanks gain. 2.2 2012 110 utility Orkney Grey
Also
Previous
90 TD5
Discovery 3
Early Discovery.
Post #212288 19th Feb 2013 12:59am
christyler
battery cable
the general rule of thumb with winches/ battery cables etc is the thicker the better, thicker cable gives less voltage drop over a given length when drawing heavy current through it.
i use 50mm2 cable for all things battery/winch related.
Post #212289 19th Feb 2013 1:10am
jayaway44
If going to a 12 way fuse board do you need to fuse it down on the way? 2.2 2012 110 utility Orkney Grey
Also
Previous
90 TD5
Discovery 3
Early Discovery.
Post #212292 19th Feb 2013 8:06am
The battery earth cable size is 35mm - buy a terminal for a 35mm cable
You don't fuse earth cables only live
There is a mega fuse already fitted in the live / positive cable
Hope that helps
Post #212296 19th Feb 2013 8:28am
MartinK
I have a similar query...I'll post it in case it helps...or maybe someone will tell me the error in my plan Question
Following the negative line from the battery, it leaves the seat box at the trasmission tunnel, then splits under the chassis member. One part goes onto a M8 bolt on the chassis, and the other (thicker) end goes onto the back of the gearbox (from memory).
Rather than make a change in the battery box (warranty concerns), I was going to crimp (and insulate) a 8.4mm Ring Terminal onto the chassis earthing point, and run a 27 amp cable back into the seat box...
On the positive side there's a spare point on the battery lead connector anyway (it's just the earth/neutral that doesn't have a spare easily-accessible connection).
Would my plan be OK? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #212314 19th Feb 2013 9:25am
Yes, no problem
Post #212315 19th Feb 2013 9:28am
MartinK
Go Beyond wrote:
Yes, no problem
Great thanks for the help Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #212317 19th Feb 2013 10:01am
