Home > Maintenance & Modifications > Is it worth rebuilding a Caliper?
x-isle
Whilst fitting my wheel spacers on the weekend, I noticed a small, tiny amount of fluid on the nearside front brake disk.
Of course, couldn't resist, had to have a taste.... Laughing
Was a bit sweet, so is possibly some brake fluid (although did taste more like antifreeze, but can't be that).
Anyway, I cleaned it away and so far there's no trace of more of the stuff.
However, it's come from somewhere, so I'm suspecting a piston seal to go soon.
So, I look at rebuild kits and they are around the £10-£15 mark, then you have to add the time to actually do the work versus just getting a nice new shiny caliper instead as looking around I've seen them between £44 and £80.
I'm guessing these are not genuine replacement ones though?
What's everyone's thoughts? Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #212126 18th Feb 2013 2:34pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Callipers are fairly easy to rebuild/repair, the pistons can become pitted and leak past the seals, the best way to check is to remove the pads and check around the pistons for fluid.
In most instances a full rebuild/replacement is not required and the pistons/seals can be replaced, and if the pistons are pitted these can also be changed. Stainless pistons are well worth it if you are keeping the truck and genuine seals are the way to go as the after market ones are often more trouble then the money you save. Although fitting the seals can be fiddly so you may want to order a couple of spares as as they are easy to destroy... Unless they are in a really bad state don't split the callipers, by the book they are not a serviceable item and they don't sell the seals but other o-rings will fit.
People have fully rebuilt them without issues but unless you are confident I wouldn't bother and would get new ones as brakes are not to be messed with.
Jason.
Post #212145 18th Feb 2013 3:46pm
x-isle
Cheers Jason,
A rebuild doesn't bother me, done plenty over the years. Just the cost and bother of it all. After getting some SS pistons and a load of seals, you are eating into a chunk of % of replacement cost of the caliper. Craig Rogers
2007 Puma 110 XS
Post #212146 18th Feb 2013 4:00pm
geobloke
This is one of the next tasks I have set myself. After replacing the calipers on the 110 shortly after buying it I kept the original calipers and plan to refurb them with stainless pistons... and why, because after 4 years the pattern parts caliper pistons are corroding badly... Big Cry
Post #212148 18th Feb 2013 4:03pm
x-isle
That's possibly another way to do it.
Buy some 2nd hand calipers, recondition them with SS pistons, swap over, recondition the ones removed and sell them on! Thumbs Up Craig Rogers
2007 Puma 110 XS
Post #212150 18th Feb 2013 4:05pm
jasong4110
x-isle wrote:
Cheers Jason,
If one's going then the others could be on the way also, it really depends on how long you intend to keep the truck there are a lot off poorly made replacement parts on the market and brakes are not one of the things I would want to scrimp on and would not be fitting cheap after market parts.
I have rebuilt mine with SS pistons so are happy that they will last a few years and not let me down when I need them most.
Jason.
Post #212151 18th Feb 2013 4:06pm
x-isle
Thumbs Up
Yeah, hence my other direction with getting some 2nd hand ones and rebuilding them.
EDIT: or maybe just do the ones on there. Too many decisions. I hate making them! Rolling with laughter Craig Rogers
2007 Puma 110 XS
Post #212152 18th Feb 2013 4:07pm
x-isle
Can anyone confirm that these are the correct seal kit and Pistons. It's for a Puma XS so has the vented disks, although I don't think that will change the seals as I'm pretty sure both vented and non-vented essentially have the same caliper, but there is a spacer between the 2 halves of the vented version, so the piston bodies are the same. Won't necessarily purchase from Paddocks, just a reference.
Seal kit
http://www.paddockspares.com/smn000060g-fr...l?___SID=U
Pistons
http://www.paddockspares.com/stc201s-front...l?___SID=U Craig Rogers
2007 Puma 110 XS
Post #212157 18th Feb 2013 4:21pm
Glynparry25
^^ They are correct.
As mentioned above doing the work yourself with SS/ good seals will give you the peace and mind that they will be good for the forseeable future.... rather than putting a set of 'normal' callipers on and them going bad in half the time.
Exactly what I will be doing with mine Mr. Green
Glyn Dog Sheep
Post #212191 18th Feb 2013 7:16pm
x-isle
Cheers for the confirmation Glyn! Craig Rogers
2007 Puma 110 XS
Post #212226 18th Feb 2013 8:55pm
jst
in the past i have always rebuilt calipers. but lately with the cost of OME ones coming down i have just bought replacement calipers, then rebuilt and sold on the old ones for pretty much what the new calipers cost me Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #212239 18th Feb 2013 9:50pm
x-isle
That was the reason for my original post. It does seem like less faff but I've bought new pistons and seals for the one side only for now. Craig Rogers
2007 Puma 110 XS
Post #212244 18th Feb 2013 9:56pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Are the paddock stainless pistons any good? Ive heard before that some of thecheap ones are too rough a finish compaired to the chrome on the normal ones and knacker the seals quicker?
Pete
Post #212250 18th Feb 2013 10:11pm
x-isle
The Paddock ones are Bearmach. Craig Rogers
2007 Puma 110 XS
Post #212253 18th Feb 2013 10:16pm
When I faced the same dilemma last year I bought new Delphi calipers and then rebuilt the old ones ready for next time.
That way the Defender is VOR for a much shorter time and the rebuild isn't hurried (plenty of time to paint the calipers properly).
Post #212320 19th Feb 2013 10:05am
