![]() | Home > Technical > How to fit xs side step/bars instructions? |
This any use?
http://topix.landrover.jlrext.com/topix/co...View=false An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682 ![]() ![]() ![]() |
This confused me when I fitted XS sidesteps to my County 110. So I went to the dealer and looked under a XS to see how they connected.
The 2 bars which connect from the step to the chassis go to a hole in the chassis where there's no obvious threaded hole (on a County) ...because it's expecting a rivnut. I bought 4 x 12mm (M8 I think) stainless bolts with nyloc nuts, and bolted straight thru the chassis (there's a corresponding hole at the other side of the chassis rail). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Stay is - DFE500100PMA about £10.50 each (2 needed - 1 per side)
Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
Hi Guys,
thanks for the help so far ![]() Porny i have found this and there is 4 bars?, is this right? as i thought it was just two and the ones that go to the front of the step is this correct? Stu |
As long as we are talking genuine part: 90 has two (one per step), 110 has 4 (2 per step). Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
i think they are gen but i pick them up tonight so if need be i will fabricate the 2 rear supports if needs be as i bought the steps in mint condition for £65
![]() here they are: ![]() Click image to enlarge Stu |
They look genuine... the support goes at the front of the step - (left of picture) - you can just see the tab it bolts to (the bottom of the front curved bar). Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Thanks Porny, been a great help as normal will post up how I get on
![]() What bolts will I need to fit these as dont come with any? Stu |
Factory or dealer fit is a rivnut in the chassis. If yous isn't an XS, there won't be one. You could either install a rivnut, or bolt right thru the chassis (which is what I did) using M8 x 110m bolts and nyloc nuts (with washers of course). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
I have the fitting instructions for the 90 somewhere, if you PM me your email address I'll scan them in and mail them.
Thanks for the email fella thats a Big help and i now see how they go on so will post up once they are fitted ![]() |
f15hie Member Since: 14 Feb 2013 Location: Kent Posts: 153 ![]() ![]() ![]() |
Not a great picture but you get the idea
![]() Click image to enlarge Shows the bars fitted A few posts to go Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Now fitted and all i need to do now is buy the support bars or make them myself and going to upgrade the nuts and bolts used, but cant grumble at £65 for gen LR Side Steps
![]() ![]() Click image to enlarge |
would these be the same as what would use on the front mounting points of the steering guard that goes through the chassis? |
