![]() | Home > Puma (Tdci) > Turbo 'whoosh' |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Split/cracked pipe perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
| Vera Member Since: 08 Oct 2012 Location: Nuneaton Posts: 130
maybe. Need to have a look when it's light tomorrow. Doesn't seem to be affecting the power tho. '09 SVX #200 '10 Morphy Richards.. I mean Prius |
Vera they can be hard to spot especially if it leaks under pressure you may not see it. Get a really decent torch and a fine toothcomb.
| me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856
Soapy water will help you find any leak.
So... On the way back from Melton Mobrey, now getting a LOT of smoke fron the exhaust under any acceleration at all. Absolutely mo loss in performance, and other than the "whoosh", no odd/troubling noises..... Grrrrrrrr '09 SVX #200
Smoke but no loss in performance? Sounds like the turbo is still working and the MAF is registering a load of air and fuelling accordingly, but for some reason the air is not getting into he mix.
Found it. Bolt coming through from the wing has punctured the hose to the inter cooler from the turbo. Has caused a 1" gash in the hose. At least now I know
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Er...is this a LR bolt or one of yours
But shout it at them in German because life is also terrifying and confusing... |
Very LR. Will be getting dropped off at the dealership in the morning '10 Morphy Richards.. I mean Prius |
Please could you post a piccy or describe exactly where it is - should be added to the list of "LR screw-ups that need to be corrected before self-destruct"
On that right now '10 Morphy Richards.. I mean Prius |
Great news, well done. Treat every day as if it is your last....one day you will be right!! |
Pretty awkward to take a photo of, but hopefully it gets the gist accross....
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated '10 Morphy Richards.. I mean Prius |
I'll be checking mine a bit later But shout it at them in German because life is also terrifying and confusing... |
| All times are GMT |
